W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: gordon on March 18, 2022, 20:46:54
Title: Hardtop quarter lights
Post by: gordon on March 18, 2022, 20:46:54
I'm grappling with installing the quarter lights. I've read the technical manual and numerous postings. Others have asked ( and not had a response) to the following questions
Should the hardtop be positioned correct side up or upside down, and also should I be attempting to fit the glass from the inside or outside of the hardtop? I presume that I should start by inserting the rearmost corner first into the bottom channel?
Any guidance would be much appreciated, thanks Gordon
Title: Re: Hardtop quarter lights
Post by: johnk on March 19, 2022, 05:33:56
Install them with the top upside down from
The inside. This allows better leverage as you can Pull the window up into the chrome at the base of the top (towards you) while trying to push the opposite end of the glass into the channel by hand.  When you get it close use a very thin scraper to leverage the window the rest if the way in. Only took me
About 15 minutes a side using this method.  I tried following detailed instructions posted by another member about doing it with the top right side up and just could not get that method to work for me. Note that you do not need to remove the chrome trim on the bottom outside lip of the hard top below the window as you install from the inside. This piece is easily damaged if you try to remove it.
Post by: gordon on March 19, 2022, 11:23:40
Thanks John for your quick and clear response, I'll have another go at it later today. I presume that I should start by inserting the pointed rear corner first?
Thanks Gordon
Post by: johnk on March 20, 2022, 05:59:23
Yes
Post by: gordon on March 21, 2022, 11:34:35
John's advice was spot on. I used copious amounts of washing up liquid soap all round the glass, inserted glass into rearmost corner then used a metal spatula to lever the glass upwards into the bottom track. I used a small clamp with a block of wood to clamp the corner of the glass at the  the top of the B post progressively tightening as I used the metal spatula to lever the glass into position. This corner is the pinch point
First one took about 15 minutes, second less than 5 minutes  , I think that loads of suitable lubricant makes the job so much easier
