W113 Pagoda SL Group => General Discussion => Topic started by: Pawel66 on January 14, 2022, 20:48:07
The Plan for today was to install overhauled alternator...
And you successfully completed the job, right ?
jz
Well, what you see on the floor is current status...
Pawel, it is a good plan to have all the parts and tools in order, so I say you had a successful day tomorrow is another day :) right ... right
Dieter
That is right!
I had alternator out. It came back. I said - let's just take a look if there are no leaks, etc. before install and let's check if the PS pump is tight after last year removal. There we were... radiator, water pump, PS pump bolt damaged, as the fan was out - let' s refresh it... i also have doors disassembled for shifters repair, soft top disassembled for V elbow elimination... the car is in pieces.
