W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: gordon on November 28, 2021, 20:24:37
Title: Auto trans safety switch/ interlock
Post by: gordon on November 28, 2021, 20:24:37
Auto transmission has been removed but the safety switch/ interlock remains. (65 230 sl) In order to start the car can anyone say if the lever on the switch should be all the way up ( or down) to replicate neutral or park on an auto box.
Thanks in anticipation
Title: Re: Auto trans safety switch/ interlock
Post by: Mike Hughes on November 29, 2021, 01:21:30
What a great anti-theft device!
"Park" would be all the way down, around four o'clock. "Neutral (0)" would be around three o'clock. There are two parallel lines cast into the cover. The lever should be positioned squarely between the lines in "Neutral (0).
Post by: Peter on November 29, 2021, 09:15:16
Maybe this helps.
Post by: mnahon on November 29, 2021, 13:10:22
You may have the 4-pin switch. Here's the corresponding diagram.
Post by: gordon on November 29, 2021, 14:05:40
Thank you for your quick and helpful response. I do intend to use the switch for anti theft.
