W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Leester on September 13, 2021, 18:13:17
Tried searching - maybe missed it but Authentic Classics sells a piece plastic slide set for the accelerator pedal. When I looked at my old one, I only had one of the two plastic pieces. I assume these enable the pedal to slide more easily on the shaft but I can't quite figure out how they should be installed on the back of the pedal. Anyone know? Thanks in advance.
Lee
Auth Classics part: https://www.authenticclassics.com/Mercedes-Slide-Plate-set-for-Gas-Pedal-p/auth-009655.htm
The slotted one against the bottom solid one top.
Many thanks!!
