W113 Pagoda SL Group => Question and comments on Originality => Topic started by: CraigD on June 14, 2021, 14:26:34
Title: Euro Headlight Fit - Gap?
Post by: CraigD on June 14, 2021, 14:26:34
There's a gap below the euro headlight chrome in this photo.  Is this normal from the factory?  I've seen in a couple cars...
Title: Re: Euro Headlight Fit - Gap?
Post by: Pawel66 on June 14, 2021, 16:27:10
There is a bit of a gap, but I am not sure if this wide. There is a channel in headlight housing for water to flow away, so such big gap is not needed, I think.
Post by: RAY on June 14, 2021, 17:33:22
Also I believe the screw should be chrome plate slotted ?
Post by: Pawel66 on June 14, 2021, 21:49:34
It is a very special screw. Yes, chromed and it has rounded tip so that it is easy to fit it in position to the threaded orifice.
Post by: Benz Dr. on June 14, 2021, 22:16:55
The top of the chrome is actually just slightly lower than the top of the fender on a perfectly fitted headlight.  It's not easy to get one to fit that well.
Post by: Tyler S on June 15, 2021, 13:50:55
It is common to have a distorted headlight bucket if/when the front bumper was ever impacted. The bumper tends to ride up and pinch the bottom of the reveal. These areas aren’t usually repaired correctly. It is more noticeable on euro headlights as the fixture plate is much more rigid than the US version.
Post by: RAY on June 17, 2021, 08:15:20
Pawel,
I recently bought 2 new screws for this purpose which were advertised as 5 x 16 but when I tried to fit them they were slightly to large a diameter thread and the slotted head looked to large to sit in the cup of the frame comfortably.
I ended up using 4 x 16 chrome slotted which threaded in perfectly and the screw head sat nicely in the cup.
Neither had the special rounded tip.
Post by: Nicolas Aristodemou on June 17, 2021, 13:44:47
I remember I had the same issue when converting my headlights to EU spec. Fortunately, at the same time I war replacing my front fenders as well as the front grille surround panel and my fitter had a hard time with his cutters and brazing torch to make everything fit.... you can see him smiling on the attached photo as well as another photo of the "finished product"  :D
Post by: Shvegel on July 26, 2021, 12:41:27
There is a factory seam in that very spot.  what you are seeing may just fall under manufacturing tolerance.
Post by: Pawel66 on July 26, 2021, 13:17:41
Pawel,
I think all the screws there are M4 and the 4 that hold the headlight should have heads smaller than standard (not to touch the glass). All 5 had rounded tips to make it easier to fit them.
