W113 Pagoda SL Group => Commercial Advertising => Topic started by: lpeterssen on April 22, 2021, 11:28:18
Dear friends
For sale one original Mercedes W113-230SL fully refurbished in perfect condition. This is for a 230SL LHD manual transmission. Price 1,350 usd OBO. Plus shipping of course.
The charging system loop has been updated to accommodate internal regulated alternators like BOSCH AL66X which fits perfect on Pagodas. Cables on the charging loom (alternator/starter/main light switch) have been replaced with new ones with increased capacity.
The wiring harness has been care fully labeled in all its terminals. It is included a main fuse box, to reduce installation time and to avoid errors.
More info per direct messages or following this link to my listing on eBay
http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=294131361963&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg&toolid=11111
Best regards
Eng. Leonardo Peterssen
Dear friends
I am dedicated to my hobby with Mercedes Benz and it’s electrical systems.
Anyone interested in rebuilding his own wiring harness to keep originality or because lack of new options for his particular car, contact me. I will help you in all the process.
Base rate for a main harness rebuilt service USD 1,000.
Particularly interesting are those cars for which is impossible to source a new harnesses as: w108/109/111 and 112 coupes or sedans. Plenty of experience on those.
Also can manage more complex cars as w111-3.5 and similar motorized cars.
Modifications to main harness to accommodate newer technologies or options that came on later Mercedes cars are also feasible. Examples:
1. Adding a hazard relay sub wiring harness. Eliminating original flasher
2. Modifying charge system to use more modern internally regulated alternators like Bosch AL66X, and increasing charge capacity
3. Modifying Ignition circuitry to use later original Mercedes transistorized ignition, which still uses ignition points, as a triggering device instead as a high current passing through element, increasing therefore lifetime expectancy by 400% and keeping the original look and distributor.
4. TTS override circuitry
5. Electrical wiper pump managed from the foot mechanical pump.
6. Low brake fluid circuitry
7. Buzzer system when lights are left on and ignition is off
And creativity is the limit.
For those not worried about originality can embebed alarm systems into the original wiring harness and make it unnoticeable.
Best regards
Eng. Leonardo Petersssen
Best regards
I have available for sale the following MERCEDES wiring harnesses. Fully serviced and refurbished like new:
1. Main wiring harness for W113 230sl with accesories: usd 1,550 OBO + shipping
http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=294131354652&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg&toolid=11111
2. Main wiring harness for W109 300SEL automatic with 2.8 engine (later model) USD 1,590 OBO plus shipping
http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=293724893977&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg&toolid=11111
3. Main wiring harness for W108 280S automatic usd 1,450 OBO plus shipping
http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=293764744713&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg&toolid=11111
4. Main wiring harness for W108 250S manual (early version) usd 1,290 OBO+shipping
http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=293155613142&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg&toolid=11111
5. Main wiring harness for w110 automatic (US spec headlights), will post cables later on eBay
. http://rover.ebay.com/rover/1/711-53200-19255-0/1?icep_ff3=2&pub=5575378759&campid=5338273189&customid=&icep_item=294146307138&ipn=psmain&icep_vectorid=229466&kwid=902099&mtid=824&kw=lg&toolid=11111
An many others, just ask for availability
Dear friends
Attached some pictures of another perfect job that I just completed.
Enjoy, and think, the electrical system on your car has never been rejuvenated, nothing last forever.
This work was for a customer in Chile who is doing a wonderful job on his w108-280SE. Main, secondary and A/C wiring harnesses have been rebuilt up to the minimum detail.
Best regards
L.peterssen
Leonardo,
I am in the process of restoring my 1970 280SL and will want to either restore or replace my harness. My harness looks good, but in my experience with restoring Corvettes, it is better to replace the old harness with a new one. I've seen a few Corvettes burn up due to old harnesses. What is it you do to restore harnesses and how much would it cost me to have my old harness restored? Is your restored harness ready to go for installation upon receipt? My car has an auto trans and is LHD. Thanks for any information you can provide.
Sincerely,
Mark Spencer
Dear Mark
Will send you a PM right away
Best regards
L.peterssen
Dear friends
See attached pictures from a recent sub wiring harness I made from scratch for a customer in SINGAPURE who had an aftermarket a/c system on his w108 RHD but wanted a professional approach for it now that he is restoring the car.
The logic is this:
1. 1x main power relay taking energy directly form post T30 at the battery
2. 1x change over relay cutting power to main relay when engine is being cranked
3. 1x relay controlling the condenser electrical fan
4. Electrical condenser fan is triggered by radiator water temperature reaching the desired level via an adjustable thermocouple and also triggered by refrigerant pressure reaching a predefined threshold
5. Compressor protected against refrigerant gas escape cutting it off if that happens
6. Auxiliary fuse box for the system.
Best regards
L.peterssen
Your work looks very good. Hats off as I am lost when it comes to electricals. Hope you are able to contribute to many restorations.
Looks very professionally made. Will get to you for a W128 when its time comes.
Dear friends
Many thanks to Cees and Pawel for their nice comments. When the time comes I will do your wire harnesses with glad at a very reasonable cost with the quality and passion I put on all them.
Best regards
L.peterssen
Dear friends
I found on eBay a new wiring harness for a Mercedes Ponton. If anyone wants to give his cars that chance of having a new electrical system here is the link.
The harness comes without connectors and accesories. It requires work to be operational, work that I can do that with pleasure for you at a reasonable cost. Just PM to study and quote your particular case.
Best regards
Leonardo Peterssen
Dear friends
For those who think that the wiring harness of your cars is a robust one, and believe everything is fine because It works, see attached photos to realize what is happening there under thick layers of tape or electrical tubing.
Best regards
Leonardo Peterssen
Engineer and Mercedes passionate
What happens is the second rule of thermodynamics (if I remember correctly from school): within a certain frame of reference entropy increases with time. :)
Thank you for sharing!
Another project just finished for a happy customer in Peru.
This is a w111-220SE coupe wiring harness converted to run on zenith carburetors with electric choke. Has a relay for the engine bay inline electric pump, at a much lower pressure than the original pump placed below the trunk area, and with a safety inertia switch which will cut power to it in case of collision.
Best regards
L.peterssen
Dear Friends
Just finished a project that some may consider not respectful of car roots, but I just helped the customer to solve the situation created by previous owner.
This is the case of a W108-280SE fuel injected that lives in Dominican Republic. This car as lives in a place where not many mechanically fuel injected Mercedes specialist exist, so at some time of its history they decided to switch the originally FI M130 engine for a diesel OM617.
Of course actual owner of the car received the heritage of some engineering errors made during that conversion. And nevertheless the engine works, the control part of the pre-glow system and the engine shutoff system is failing.
At the beginning I though this was an usual w108 wiring harness restoration. The complexity came after once the owner told me about the w123 Diesel engine conversion.
The implementation of that engine conversion brought some new problems, as the heat generated by the turbo compressor which affects the performance of the original A/c system. On all w108 the refrigerant high and low pressure refrigerant hoses are run trough the right side of the engine. The proximity with the turbo generated and undesired excessive heat exchange. Therefore, to make it work it right, all components will have to be moved to the LEFT SIDE, and as a consequence the original A/c wiring harness has to be modified or remade. The later was the solution taken.
Originally the pre-glow system used on this conversion came from a w115 where the pre-glow plugs are connected in series. That was changed to the logic used on w123 300D from year 1980 up where a new kind of pre-glow relay is used that connects the new style (faster) pre-glow plugs in parallel.
A new instrumentation cluster that came from a w115-75 was included on the project which made me change the instrument cluster connector pin positioning (pin re mapping) to make it work properly. W115 from that year used electric signals for the temperature gauge, and also has a diesel glow plug light indicator.
The engine didn’t shutdown when turning engine to the off position, maybe because of a mis adjusting of the fuel cutoff cable, and customer asked me to give it an electric solution, so a Normally closed fuel cut off valve was added.
If you have a similar project on hands write me. I may help.
Best regards
L.Peterssen
Better pictures of current project car
Hello Leonardo,
I have sent you several text messages and emails and tried to phone, but I have not been able to reach you. Is everything alright?
According to DHL my harness is in customs at Valencia, so hopefully, once it clears it will go out for delivery. I am hoping that happens today.
Roland
Dear Roland
We had a power cut as a consequence of a sky lighting that lasted 32 hours. The event occurred on a major 13.5KV substation that feeds energy to more than half the city were I live (1.5 million people) and therefore there were no phones, no internet etc.
I used the standby briggs&stratton generator installed at home for short periods no longer than 2 hours to have basic things running as the fridge etc. But no phones and no internet.
We are Ok,thanks for asking.
Best regards
L.Peterssen
Dear friends
Another job just finished. Enjoy photos of the linked photo album where all the steps of the refurbishing process are shown.
https://www.icloud.com/sharedalbum/#B0QGCATCnGzPtpf
Best regards
L.peterssen
Dear friends
Some weeks ago, I finished an interesting project on which a custom wiring harness was built for a customer in Germany.
This guy bought an original W109 300SEL 6.3 which was terrible rotten at a point that he decided to buy another car with similar structure to pass all the 6.3 stuff to that body.
He sourced a nice perfect body 1972 W109-4.5.
At the beginning he thought he could transplant everything from one car to the other. When he faced the electrical part noticed that the 6.3 harness didn’t fit, specially on the cabin side as many accessories are on different places ….. , and therefore he contacted me.
He sent me to Venezuela both harnesses and wanted me to build the best of both.
Customer wanted to keep the AC system present on the 4.5 harness, so I decided to keep that harness as the base of the custom project.
As you all may know the 4.5 cars all were fuel injected with a Bosch D-jetronic system, with an ECU on the right engine bay fender, and a separated engine control harness which takes the reading for various combustion variables and do control the electric injectors.
Well all those systems and relay terminals had to be removed from the 4.5 harness.
On the other hand, basic things as the position of the alternator and ac compressor were opposite on the 6.3 compared to the 4.5
That made me to built from scratch all the charging system, and reposition the signals and relays that control the AC system.
The 6.3 has an array of relays to control the cold engine startup on the left fender close to the vacuum booster. All that was build from scratch NEW in order to have reliability. The shortcut will have to take those lines and elements from the old 6.3 harness, but I decided to take the long way, the quality way…..
A 6.3 harness has a 12 pin connector on the center of the firewall where the engine control harness is plugged in. That was build as well including some new signals that were not on the original design as is a line for the temperature sender.
The central instrument cluster branch and connector from the 4.5 was altered to fit the tachometer installed on a regular 6.3 central instrumentation, as well as a novelty which was to have an electrical signal driven temperature gauge. The customer bought an instrumentation circuit board coming from a late w114 sedan (1973 onwards) which came with that option.
The automatic transmission control on a 4.5 is totally different from a 6.3 so that part was build from scratch again to resemble the 6.3 harness.
Well those were the most important changes made to that 4.5 harness to work properly with the 6.3 engine train.
If you have a similar project please contact me through the regular channels and I will be more than happy to come with an engineer solution to your particular case.
Best regards
Here some photos of the project
https://www.icloud.com/sharedalbum/#B0QGd59qiGR6Bxc
