W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Charles 230SL on February 02, 2021, 20:14:21
I've got a slimface Europa TG on the way from Becker Autosound and I just discovered (like an hour ago) that my radio plate has been cut to fit a later (larger DIN) radio. Since I have a 230/250 radio plate, I just assumed I had a slimface radio in the car- it never occurred to me that a PO had cut the plate - until I measured it....rats!
Do not despair, they are easy to get:
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/68-a-dashboard-covering/ctre-section-dashboard-230sl-p-16736
Charles,
Bud's and Authenticclassic should have this dash piece as well.
Ask them.
Or you'll find an original one (NLA by the way): A113 689 0139.
Charles, Bud's and Authentic classic should have this dash piece as well. Ask them. Or you'll find an original one (NLA by the way): A113 689 0139. ;)
Yes, I know - its just a hassle to have to match/buy the paint, get my paint 'stuff together, and spray a new one. I've got some dark blue (DB 332) leftover from when I sprayed the wheels and hubcaps..but it'll need to be an exact match with the dash and glovebox door - which with my luck, it won't be :(. no big deal, I just wasn't expecting the aggravation.
Charles, I am sure you will find your radio plate. I’ve not turned my radio on in 7 years, I prefer to listen to my engine, in time I am certain you will too.
If you do need a radio, use your cell phone wireless with this have a peek below. I have one for 5 years and love it when I do like to listen to my own music :)
Dieter
—-> https://www.amazon.ca/Jawbone-JAMBOX-Wireless-Bluetooth-Speaker/dp/B004E10KI8
Or you can put in a big-face Becker. I am sorry this has happened, particularly after you spent $$$ for what I assume is a nice TG. Post pic of radio.
I took out a big-face Europa MU (which I mistook to be a slimface). I figured since I had a radio plate it was a slimface - I didn't realize the plate had been cut to accommodate a big face radio. I've not received the TG yet - I'll ask Tom to send a picture before it ships.
You might see if you can cancel your order unless you are planning on switching the dash metal plate...
hey scoot, I plan to get a new radio plate for the Europa TG - https://www.authenticclassics.com/Mercedes-230SL-250SL-Dashboard-Radio-Mount-Plate-p/auth-003066.htm.. I just hope I don't run into anymore surprises
I'm glad you are going that direction. Much better to have an actual small-face radio in the dash. Yay!
Yes Charles,
Definitely!
Go for it!
Thumbs up! ;) :D
The new radio plate from Auth Classics arrived yesterday. Using the old plate as a template, I drilled holes for the chrome trim, then sanded and primed it. I plan to spray it dark blue/332 over the weekend. The Europa TG from Becker Autosound will be here next week so the paint will have at least 3 to 4 days to harden. Becker Autosound sent some pictures of the radio but they're not very good.. Tom Mitchell sounded pretty busy and I didn't want to bug him for more pictures.
Pics look good to me! At least it is the right radio!
Yay for your project.
Scott
I've been side-tracked these last couple of weeks but finally managed to install the Europa TG. It looks good, sounds good, so I guess this concludes my Winter project ;)..
It looks just right and will probably work great for decades. Worth the effort.
