W113 Pagoda SL Group => W11x chassis cars => Topic started by: wwheeler on October 24, 2020, 19:14:30
I need a driver’s side (left) rear panel trim piece for a coupe/cab. This is the horizontal chrome trim that is between the upper cap and the lower side panel. It is about 31” long and has a countersunk screw hole at one end. There might be two versions of this, one that is shorter without the screw hole. The condition of the chrome is not important, but needs to be in good solid condition. I am willing to take the cap as well if needed since it is attached to that.
Thank you,
Wallace,
Can you post a picture so it's absolutely clear what you require.
I will try and help out.
I probably should have posted this earlier. I did find the piece I was looking for. Daniel Landeros in CA.
Thanks.
