W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Dips on October 05, 2019, 11:48:10
Title: Brake Booster RHD 250SL 1967 Pagoda
Post by: Dips on October 05, 2019, 11:48:10
Hi All
I've followed the advice on using this forum but now feel the need to post.
The Bakelite components in mine are damaged and I'm told beyond repair. Despair!
Is there anyone out there that has a brake booster suitable for my right hand drive car for sale?
Or can anyone help me to buy the correct LHD brake booster and have it adapted in the UK?
Any info on part numbers would be helpful too.
What is the part number for my RHD car?
What is the LHD part number that I may need to buy and have adapted?
Title: Re: Brake Booster RHD 250SL 1967 Pagoda
Post by: cfm65@me.com on October 05, 2019, 12:57:12
Hi Dips,
The brake boosters are the same. They are not L or R handed.
I suggest you place your question two subjects further down in the “ Drive train, fuel, suspension, etc”, paragraph for better exposure.
The brake boosters are still available, it seems.
Chris
Post by: Tyler S. on October 05, 2019, 13:45:44
The LHD and RHD boosters are indeed different. The RHD using a ball on the actuating end and the LHD using the fork style. The vacuum port is also in a different location. I’d suggest getting in contact with Colin Ferns (stickandrudderman) on the forum. Apparently he has used donor components from LHD boosters to repair RHD boosters.
Post by: cfm65@me.com on October 05, 2019, 15:51:52
Apologies Dips,
I got it wrong, sorry.
Chris
Post by: Garry on October 05, 2019, 23:09:01
Not only different but nearly impossible to get some of the parts for the RHS booster. Dont ask how i know, twice.
Post by: do8erman on October 12, 2019, 07:47:43
Speak to J and L Europe Ltd  based in Lancashire  good luck chris
Post by: stickandrudderman on December 12, 2019, 16:18:31
I have had drawings made for the commonly failed Bakelite post and have had a 3D prototype printed to prove concept.
The problem now is that because they use sliding seals the surface must be very smooth and hard which precludes the cheaper materials used commonly in 3D printing.
Further, there is the issue of potential liability which means the part must be made in such a way as to pretty much guarantee it will never fail.
The quotes I've had so far for machining or printing in surgical grade stainless steel are enormous so if any of you have contacts in that world let's hear it!
Post by: JamesL on December 12, 2019, 16:36:18
I'm sure I've seen titanium being 3d printed. Could that be used/ground down?
https://i.materialise.com/en/3d-printing-materials/titanium
Post by: Cees Klumper on December 13, 2019, 03:27:40
Couldn't the part be molded in Bakelite? Just remake it the way it used to be?
Post by: andyburns on December 18, 2019, 17:25:14
The T51 will w108 booster has the same identical Baker lite part in it.  The booster can be disassembled quite easily.  Then just swap out the rhd steel rods.  I did it so know 100pc it's possible.  W108 boosters are widely available.
