W113 Pagoda SL Group => Research & Development => Topic started by: cfm65@me.com on July 31, 2019, 19:15:28
Hi Guys,
Does anyone know who makes/sells a GPS Mechanical Speedo Drive for our cars?
Chris
Top
last I checked, it was about $500 to convert.
Only issue w/those is it probably takes several seconds at least for it to find the satellites after turn on.
No worky in tunnels of course.
An alternative if you swap in a Getrag 265 5-speed w/an electronic speedo output
Google:
https://www.jegs.com/i/JEGS/555/41800/10002/-1
https://www.speedhut.com/Speedbox.html
Drive Output Thread is 7/8"-18
1000 turns per mile
https://www.classicautoinnovations.com/classic
This one claims that it can be calibrated to any speedo. Speedometer cable connection: drive end:
Choice of 3/4 x 26 or 7/8 x 18
No idea of what you need to do to make this work on a Pagoda.
The fitting on the back of the Pagoda speedo head is 18 mm X 1.5 mm pitch
Neither of those threads is a match for this.
Thanks Gents,
Much appreciated.
Apologies for not having had a chance to look at the forum for a while. I have been and will be in the UK for a while(5 months)
Yes, I have looked at the three options mentioned above and I have realised that they might not quite meet my requirement, fully.
However, I’ll keep looking and I will certainly remember to purchase a 7/8”x18 fitting as well. Unless, I could find a speedo drive(mechanical or electronic) for my 265/6 Getrag.
Thanks again
Chris
