W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: NoEcm on July 04, 2019, 13:43:52
Title: Early 1967 250SL - Master Cylinder Replacement Questions
Post by: NoEcm on July 04, 2019, 13:43:52
Master Cylinder appears to be frozen and leaking:
(https://i.imgur.com/rANZ16L.jpg)
(https://i.imgur.com/D1lz5nv.jpg)
Early chassis (below #02980) so it appears that I'll need the more expensive Master Cylinder p/n  001-430-89-01
Questions:
1. Does a new master cylinder include the grommets for the fluid reservoir?
2. Does a new master cylinder include the O-Ring that fits between the master cylinder and brake booster?
3. How difficult is it to move the brake fluid reservoir between the old master cylinder and the new one?
4. When I just barely touched the little rubber plug on the brake fluid reservoir nipple it fell apart, any suggestions on how to make or secure a replacement?
5. Any other tips or suggestions?
Thanks!
Title: Re: Early 1967 250SL - Master Cylinder Replacement Questions
Post by: Jonny B on July 04, 2019, 15:03:33
Authentic classics has the reservoir and their part includes the little black rubber piece - reuse the clamp you have on yours.
Buds Benz has the picture (and it includes the black rubber piece) but their's is listed as NLA
Post by: Pawel66 on July 04, 2019, 16:09:40
I am not 100% sure, but this plug, I think A 000 987 03 45 (?), may be available at MB (it is here in Europe, if it is this part - you do not see it in the picture in the EPC, but it is there together with the clamp on the parts list, it may be this one you ask about). It is $ 3-4 here.
Keep the original small clamp, I think it is quite rare.
I am not sure if the fluid reservoir you have is available in its exact original shape. I would keep it (I think this is what you are planning to do). It has been discussed in another post that a good wash with soap water or washing powder may significantly improve its look (yours does not look that bad, actually).
The sealing ring between the master and booster is available in MB, ca $5 (A 004 997 32 45).
I do not know if master cylinder kits include the reservoir grommets.
What I see is that the grommet appears as a separate spare part "As of ident. no.: 043 002980" and it has a part number A 000 431 09 35. This chassis number marks also the change of master cylinder types or PN. Could be the earlier one had grommets built in the later one - separate - but I am not sure, you would need to confirm.
There are also some repair kits in MB, but do not know if applicable in your case.
Post by: NoEcm on July 24, 2019, 06:28:15
I found a temporary solution to that little black plug on the master cylinder reservoir:
"Dorman Help! 47396 Vacuum Cap". I paid less than $4.00 for the assortment of 8. Perfect fit and I was able to use the original clamp.
(https://static.dormanproducts.com/images/product/medium/47396-007.JPG)
Keep in mind that this is only a temporary solution as I do not know how compatible this rubber is with brake fluid.
Post by: mauro12 on October 17, 2020, 17:55:52
I have a 250sl early chassis too and I’m starting to think that would be a great idea to buy the new master cylinder and save it. I read somewhere that this pieces will be not longer available shortly or maybe the price will be near 400/500 dollars. What do you think could be the best way to prevent brake fluid failure? Try to use more often the car and so the brakes?
Post by: NoEcm on October 17, 2020, 20:01:20
I have no opinion of buying a master cylinder and saving it for future use. $500 is a lot of money and there are other places I can spend that now. By not buying one and setting it aside for future use I hope I don't kick myself down the road.
But as an FYI the leak that I had was from between the reservoir and the master cylinder. Simple and cheap fix (under $25). Google "ATE 390001" and you'll find the repair/reseal kit.
Post by: thelews on October 17, 2020, 20:16:13
If you drive your car and bleed your brakes regularly to remove moisture, your MC should last just fine.  Worn seals can be replaced.  I would also think there are generic solutions that would not look original.
Post by: inci on October 18, 2020, 03:02:31
take a look at rockauto.  remanufactured/tested. $45
CARDONE 111919
Post by: mauro12 on May 09, 2021, 21:18:36
Hi guys , I would like to know if the old style brake fluid reservoir ( the one from ate NLA)
Has the float level sensor and where is located . Since I’m going to replace the master cylinder, I would like to know if I have to disconnect some wires or remove some sensors inside the reservoir itself .
I have never seen wires in the old style reservoir like for the later one ( 280sl ).
In case I decide to replace with a new reservoir ( reproduction unfortunately) , what I have to do ? Put  back some sensors ? Thank you
Post by: Jonny B on May 10, 2021, 15:15:19
The early style reservoirs do not have the brake level sensors.
Post by: mauro12 on May 10, 2021, 16:25:23
So there is not any problem about low brake fluid and activation of the fuel pump while doors are opened ?
Considering that there is not any floating sensor , there should be not any warning light on in case of low fluid , right ?
Post by: Jonny B on May 11, 2021, 01:19:29
Correct, the door open , car run is for the "creative" wiring MB did with the new type reservoir and sensors.
