W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: erickmarciano on March 11, 2019, 21:12:59
Hi guys
Want to install my rear axle . What is easier? Should I install the center bolt in the mount or should I take the mount off the 4 bolts , install the center bolt then put back the 4 bolts?
Erick
Normally the center bolt is attached last. In fact there is a factory cone shaped tool which is place on top the vertical arm, to help center it into the hole while the rear end is raised into place. Once in place, the special cone tool is removed and the bolt is installed.
Sorry was not clear I ment the center bolt in the trunk ( center mount)
Yes, that is what I meant also.
