W113 Pagoda SL Group => W11x chassis cars => Topic started by: mBdrvr on August 25, 2017, 01:29:47
Title: w111 Washer Pump Location
Post by: mBdrvr on August 25, 2017, 01:29:47
I  know the 250SE washer pump is located somewhere near the brake booster.
Does anyone have a picture or somehow indicate where it lives?
Paul
Title: Re: w111 Washer Pump Location
Post by: wwheeler on August 25, 2017, 14:47:50
On a W111, that is the washer fluid reservoir. The pump is a foot operated bellows and should be on the left side of the foot well. Normally where the high beam switch would be on most cars. It has a switch on it that automatically starts the wipers while the washers are squirting.
Post by: rgafitanu@gmail.com on August 25, 2017, 18:46:15
I think he is asking where the reservoir is located Wallace. On mine is hanging of the battery top frame although I doubt that is the original location.
Post by: mBdrvr on August 26, 2017, 00:25:11
My car evidently was retrofitted with an electric washer pump. The old rubber bladder is still there. Thanks for the help.
Paul
Post by: wwheeler on August 26, 2017, 02:35:22
Yes, the reservoir is indeed mounted on the upper battery frame. That is a stock position. The V-8s (3.5L) are of course different. But as far as I know, the washer pump was always a foot pump on the W11 cars.
Post by: mBdrvr on September 15, 2017, 18:12:25
Yes thanks all. The car was retrofitted with an electric pump. The original works fine. Thanks again,
Paul
