W113 Pagoda SL Group => W11x chassis cars => Topic started by: wwheeler on August 18, 2010, 21:19:56
I wanted to get some opinions from people about the effectiveness of the hydro-compensator vs. the spring compensator. Does it have a significantly positive effect on handling and the suspension? I know it does work to level the rear height during heavy loads. Since I do not carry heavy loads, the leveling feature will not benefit me.
My '68 originally came with it, but now has been replaced with the spring. The earlier cars did not have the "automatic" compensator to level the car's rear height under a heavy load. I am considering replacing the spring with the expensive hydro-compensator, but want to get some feedback before I decide.
Thanks for your opinions!
I considered installing a H.N. Compensator on my 69 280 se coupe while I was rebuilding the whole suspension system about 9 years ago. I couldn't find any reason to do so after doing a lot of comparison research between the much less expensive rear diff. spring versus the H.N.C. . Nine years later , I have no regrets. The suspension is firm and holds firmly on corners etc......No height issues in the rear when travelling with a full trunk of luggage . I'm glad I didn't spend the $12000.00 that they were going for at that time while I was considering it....My opinion is that you should spend the extra money else where. I think I bought the regular diff. spring for less than $150.00 . :-\
I drive a W108; 250SE. IMHO, the Boge hydro-compensating spring gives superior driving performance. I had to replace my failing Boge with a spring, then after refurbishing the Boge at ZF, I re-mounted it. A relief.
To each his own, I suppose. All depends on how (fast) and on what roads you drive your classic, and the general condition on all suspension parts. I have renewed all rubber parts in my chassis. Also how the chassis is adjusted affects the driving experience.
/Hans in Sweden
PS. The Boge hydro compensator is no longer manufactured. However, the Boge factory, nowadays part of ZF group, has for the German M-B Clubs made a special run to enable re-furbishing of old worn-out units. The work comes with a guarantee. See Web: http://www.zf.com (http://www.zf.com)
You can mail to Herr Dieter Narres; dieter.narres@zf.com to obtain detailed information about the refurb DS.
Thank you for your thoughts. All that is left to do now is JUST decide.
