W113 Pagoda SL Group => Electrical and Instruments => Topic started by: Largeowner on August 25, 2008, 08:59:46
I recently burned out my number 2 fuse. It is the legendary "short" fuse which I gather is NLA.
What is the Pagoda Group approved solution? Can you remove the spacer and replace with a full-size one?
Large
There was some talk about this awhile back. Last time I checked, it was available, though not from every MB parts dealer. As I recall, some referred to it as the "stubby fuse" or "stubbies," so you may want to run a search in this forum with that in mind.
I am pretty sure the Classic Center has these. They should be 25 A.
I bought a fuse set from SLS recently and all fuses were there.
The classic Center definitely has them. I got two a short time ago.
Call it impatience, call it the march of time, call it inevitable... I drilled out the spacer (took about 60 seconds) and bought replacement fuses at the local Autozone.
For me, convenience trumps "correct" since I am a "driver" and not a "displayer".
Thanks for all the replies,
Large
I just purchased this part from the classic center, it showed up today
part number
072581-025100N 25A short 1.27 each
I bought 2 just in case
contact
Tom Hanson
Mercedes Benz Classic Center USA
Mercedes Benz USA, LLC
949 598-4850
The short fuse is also available from SLS in Germany.
Item no: 258991
Retails for about 2 Euro each.
