W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: glennard on July 12, 2008, 19:27:45
Title: Can you top this???
Post by: glennard on July 12, 2008, 19:27:45
Can you top this???   You can't make this up.   A little background- Have 230SL with a bad engine, bought a '68 250SE donor sedan w/frozen engine, towed home 70 miles, pulled engine/tranny as unit, pan off, oil pump frozen in, got bevel gear off idle shaft(oil pump, etc) with a little help.  Then, the sprocket came off-fell off the idle shaft.  No key resistance.  Looked at the key.  It was a 'offset key'!!.  One of the kind for the cam shaft sprocket to offset chain stretch.
   This has got to be in Shade Tree Hall of Fame! :)
Title: Re: Can you top this???
Post by: paulr on July 13, 2008, 00:16:49
sounds like ppp to me. Pump & Pan Pulled off.!!
Post by: waqas on July 13, 2008, 09:20:33
To me it sounds more like LACK of PPP by the previous owner-- Practiced Pagoda Proficiency!
