W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: mike65 on May 03, 2008, 07:45:53
Hello all. I'm new to the sl ownership world (impulsive buy!!) and new to Pagoda SL Group.
My recently purchased '65 230sl is a "driver" that I want to fix up a little more to improve reliability (it's already almost stranded me once with a crack in the upper rad hose).
My question is: where is the best source for parts? I dropped in to my local (London Ontario, Canada) MB dealership and they needed the VIN to check parts availability, then I could order from that list. Seems kinda slow. Parts Online Canada lists the upper rad hose for $25, but I'm skeptical about whether it really is the correct part and would be even more nervous on more expensive parts - anyone had luck with them?
I really just want to do some simple maintenance(replace all hoses, belts, fix the slightly loose steering, etc) plus some safety upgrades (maybe seatbelts and headrests, if it doesn't ruin the cars originality too much - I'd even considering buying seats with headrests so I can keep the originals...)
I've tried matching the rad hose at Canadian Tire (no luck). Does anyone have a "cross reference" to other MBs or vehicles for parts like this?
Any advice would be appreciated.
Thx,
MO
mike,
there are several sources for parts, most of the one's I know are in the u.s.
I have used the MB classic center. using the vin they can sell direct.
SLS has a great site for a parts , easy to view and you can order from them. (although I have heard it take a while to get parts)
I have also used
http://www.kkmfg.com/ - they are very help full and know alot about sl's
here are some other sources
http://www.budsbenz.com/
http://www.millermbz.com/
FOr OE parts you can also try
http://buymbparts.com/
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Dan Caron (Benz Barn) is your best source, located in Ontario, Canada. Not only are his prices fair and reasonable, but Dan is a world of knowledge on all Mercedes. His is also active in this forum and attends many Pagoda gatherings. Here is his contact information:
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
