W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: karmannghia60 on April 28, 2008, 18:06:39
Title: Revs dropping
Post by: karmannghia60 on April 28, 2008, 18:06:39
Hello
When the engine has been running for 1/2hr or more and at operating temprature, the revs drop and the car often stall (auto transmission). What could be the issue?
Raf
Melbourne Australia
RHD 1969 280SL
Title: Re: Revs dropping
Post by: hands_aus on April 29, 2008, 05:56:58
Hey Raf,
anything else you could add?
eg., does it re-start easily straight away or does the problem persist for 20 minutes, 2 hours or more?
Your statement says that it 'often stalls'. Are the circumstances always the same eg., at traffic lights, a certain level of fuel in the tank.
Have you changed fuel brands or servos?
How long since the fuel filter was replaced?
Can you hear the fuel pump spinning?
As you can see I am thinking a fuel problem.
BEST OF THE BEST!
Post by: merrill on April 29, 2008, 10:49:36
Raf,
could be a couple of things, however After you answer Bob's questions
we may be able to narrow your search.
Try this, when it gets warm and tries to stall, give just a little gas.
does the car continue to run?
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Post by: karmannghia60 on April 29, 2008, 18:55:33
Here are the answers
Yes, it starts easily but the revs will be low so as soon as I put it in drive or reverse, it could stall again
Yes at traffic lights. Nothing to do with fuel level
No, I use premium (98 octane) plus Valve Master
A while, 2 or 3 years but very low usage
Yes. It is NOT a fuel delivery issue. It is simply the revs drop to about 500 or 600 when the engine warms up. Obviously such low idle revs is not enough to keep the engine running once gears are engaged
Post by: hands_aus on April 30, 2008, 06:22:35
Raf,
Thanks for the reply.
I see your car is an auto.
On the top of the inlet manifold is the Constant Speed Solenoid (CSS) which is used to increase the engine idle speed when in gear.
You can watch it working with the bonnet open. Put the transmission in gear (forward or reverse) the plunger should move the throttle linkage enough to increase the idle speed.
Is it possible that the CSS is not adjusted correctly?
BEST OF THE BEST!
Post by: J. Huber on April 30, 2008, 08:07:25
Sounds a lot like a linkage problem to me (of which the CSS Bob mentions is part).
Post by: karmannghia60 on April 30, 2008, 16:48:06
Thanks for the tip, I will check it out on the weekend
Raf
Post by: karmannghia60 on May 01, 2008, 18:13:55
Solid as a rock, this thing does not move a mm. Is the plunger supposed to move in/out if I try to pull/push it?
Could be ceased I guess. The car sat in the garage for the last two years because I was overseas, only getting used for couple of weeks every 6 months or so.
Is the CSS repairable so should I get a new one? Bob, where do I get it from in Aus?
Thanks again
Post by: hands_aus on May 03, 2008, 06:01:17
Thanks again
Raf,
The plunger should move by hand. If not try to free it.
Remove the wires from the solenoid, apply 12 volts and see if it works without the engine working.
Test to see if 12 volts is being applied to the solenoid with the car running at idle, in gear.
Don't rush out, a new one costs an arm and a leg.
If absolutely necessary to replace it, you might be able to buy a working one from John Green in Canberra http://mbspares.com.au/
or Chris Stewart in Melbourne. < Chris Stewart bikesncars@optusnet.com.au >
BEST OF THE BEST!
Post by: karmannghia60 on May 07, 2008, 16:24:53
Good news & bad. I freed it and tested it, so the CSS is now working. However when I come to a stop at the lights, the revs will still be low till I just give the accelerator a slight nudge then the revs will pick up and stay up
Post by: hands_aus on May 11, 2008, 05:40:41
Raf,
At least the engine keeps going.
There could be some play in the lower linkage rod that connects the pedal to the pivot point on the lower RHS engine block.
BEST OF THE BEST!
Post by: rwmastel on May 11, 2008, 21:37:10
I would just check the fuel system because of non-use.
- Clamp the flexible fuel return line at the fuel tank.
- Disconnect the flexible fuel return line at the fuel tank, drop the end into a large (2 liter) glass jar, and remove the clamp.
- Turn the ignition key to position 1 so the electric fuel pump runs but the car does not start.
- After 15 seconds, turn the key off.
- Measure the fuel, should be about 1 liter.
Fuel delivery problems in these cars are VERY common.
Pagoda Technical Manual
1966 230SL
2006 C230 Sport Sedan
