W113 Pagoda SL Group => Electrical and Instruments => Topic started by: gnj588d on March 07, 2008, 14:30:33
Title: dwell meter
Post by: gnj588d on March 07, 2008, 14:30:33
Is it possible to buy a new dwell meter in the UK tried ebay but no luck. Many thanks Mike Rutledge
Title: Re: dwell meter
Post by: Naj ✝︎ on March 07, 2008, 15:49:54
Yes, try Halfords or similar car shop.
You can get a multimeter which will do dwell, rpm, volts, and continuity tests etc.
Gunson do one with a digital readout.
See you on the 'Essen Bus'
Post by: merrill on March 07, 2008, 21:25:36
see if you can find a dealer for the unit in the link below
I really like mine
http://www.actron.com/product_detail.php?pid=16155
 Web Price $65.99 USD
  (Digital Multimeter & Engine Analyzer)
This ingenious tool performs all standard electrical tests for on-car and bench troubleshooting. Locate faulty wiring, test electrical components, engine sensors, ignition and fuel systems and starting/charging system voltage. Pinpoint problem area and determine which components need repair or replacement.
Tests engine RPM and dwell
Measures AC/DC voltage, DC current and resistance
Tests diodes and continuity
Tests starting & charging, ignition and fuel delivery systems
24 Ranges for more accurate measurements
Locate faulty wiring and components
Audible Tone
Extra-large, easy-to-read digital LCD
Hold button retains display data
On-screen test leads connection reminder
Automatic reverse polarity indication
Automatic zero adjustment for volts and amps for accurate measurements
Low battery indication for user convenience (9V battery not included)
Overload protection on all ranges
Fold-out stand for better viewing
Includes protective boot, detachable color-coded test leads and alligator clips
Comprehensive user manual with illustrated step-by-step automotive test procedures and examples in English, Spanish and French
1 year warranty
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Post by: dseretakis on March 08, 2008, 17:06:25
I bought a used SNAP-ON dwell/tach meter on ebay and it doesn't work so I went to SEARS and bought an Actron dwell/tach meter which works well.  This won't help you since you're in the UK.
Dimitri
Post by: gnj588d on March 09, 2008, 16:13:27
Thanks for the info,got one in halfords (gunsons}thanks Naj.Yes see you on the coach
