W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: deke54 on September 15, 2007, 10:34:10
What is the Mercedes (versus Bosch) part number for fuel injectors for a 280sl, and are the injectors for a 230 the same as for the later car? Thanks
deke54,
the only injector you can get new is the bosch R2.
the dealer can give you their part number for the r2 if you want.
auto haus az has them for 97.65
http://www.autohausaz.com/search/product.aspx?sid=wpnif555s3lnye55vgipsrfz&makeid=800016@Mercedes&modelid=1342628@230SL&year=1966&cid=22@Fuel%20%26%20Air%20System&gid=6224@Fuel%20Injector
If you have R1's get them checked. some injection pump rebuilders prefer the performance of the r1's
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Thanks for the reply. There is a set of unopened Mercedes injectors available. They are advertised as being for a 230 sl. If they would work in my 280, I'd be interested. That's why I was trying to determine if Mercedes 230 sl injectors will work in a later car. Thanks again.
I have the R2 injectors on my '63 230SL. Does this affect performance or other isues?
Regards, Paul
paul
R2's will work, from what I understand R1's were designed differently.
R1 or R2 will work the same
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
