W113 Pagoda SL Group => General Discussion => Topic started by: tdun824259 on August 17, 2007, 09:59:12
I've read several posts on "seized wipers", but my problem is slightly different. I pride myself in never driving in rain. God had other plans. My wipers worked great for a few miles and then suddenly first the drivers side then the passenger side just fell to the sides of the windshield. (opposite of the park position) I stopped and was able to move the arms back to the park position without any problem. Starting the wipers again led to the same issue. I would expect that the spindle is not engaging the wiper arm rather than a linkage problem. Anyone encountering this problem, I would appreciate knowing the solution.
Tim Dunagan
1971 280 SL
Tim,
Its probably just the wiper arms that need tightening on their spindles. The spindles are conical shaped and splined while the arms arm ends are just cone shaped so they can be adjusted as required.
Just 'park' them in the right place and tighten down the nuts at the bottom of the arms.
Naj,
thanks so much. Hopefully, that's all it is. I'll tighten the nut tonight.
Tim Dunagan
1971 280 SL
