W113 Pagoda SL Group => General Discussion => Topic started by: merrill on August 06, 2007, 15:33:35
turns out the double acting selenoid on the tranny for my 66 230 sl is not working.
I did all the trouble shooting and was in contact with the tranny rebuilder and now I need to remove it.
is it possible to remove the without removing the tranny?
I have the tranny access tunnel open and have removed the closest bolt, but the bolt on the drivers side is hard to get to.
thoughts?
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
well, we (my wife and I ) were able to get to the drivers side bolt.
we ended up with her on the in side helping guide an 11 mm socket and I was in the engine compartment with a thumbwheel ratchet, 3 feet in extensions , universal joint then socket.
she held the socket on while I turmed the thumbscrew ratchet. it eventually came off.
still sucked, took us 2 hours to figure out how to get it off.
tested it , it did not work, called the tranny rebuilder and they will send me a replacement for free.
thanks all
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
Well, at least you got someone with '' girl hands '' to help you.....
well, new selenoid showed up today, it took 2 of us to install the drivers side bolt. one on the inside and me in the engine bay reaching in.
still a lousy job
new one tested and works!
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
what does the double acting solonoid do and what does or does not happen if it fails ? Mike 230
this link has all the details
http://www.mercedesdismantlers.com//16BoltInstallationInstructions.html
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
