W113 Pagoda SL Group => General Discussion => Topic started by: perry113 on May 21, 2007, 18:35:02
Title: waterpump replacement & lubrication
Post by: perry113 on May 21, 2007, 18:35:02
Hello fellow forum members.
I am in the process of replacing the waterpump on my 1965 230SL and see that there are 2 holes in the new waterpump housing. My thought is to tap and tread one of the holes and install a grease fitting for lubrication. The old pump is a replacment pump and does not have a fitting nor any threads for one to be installed. Looks like it was never serviced.
Am I on the right track doing this??
My shop manual says the pump requires lubrication every 12000 miles but does not specify the type grease/oil to be used. My thinking is to use a grease fitting and use the same type of grease used for servicing the front end. Or should I carefully insert motor oil or marvel mystery oil into the top insertion hole.
Your feedback and knowledge is greatly appreciated.
Peter Perry
Albany NY
pperry444@juno.com
Title: Re: waterpump replacement & lubrication
Post by: gnj588d on May 22, 2007, 12:36:19
Mine is a 65 car and the correct oil for the water pump is hypoid gear oil as in the back axle it has a level plug in the side and a filler plug in the top,both are hexagon bolts.Good luck, Mike
Post by: Naj ✝︎ on May 23, 2007, 16:10:12
Hello Peter,
If your new water pump does not have these two plugs then it will have sealed bearings and does not need lubrication:
Download Attachment: (http://images/icon_paperclip.gif) 230wp04.JPG (http://www.sl113.org/forums/uploaded/naj/200752318942_230wp04.JPG)
38.65 KB
Post by: perry113 on May 24, 2007, 11:30:20
Naj.
Thanks for your reply. I think you solved my question. Mine is a later style unit. Pictures will not upload.
My thought is now that one of the 2 holes is weep hole to allow fluid to drip if the pump fails. The other hole is for???
Thanks in advance.
Peter Perry
Post by: Shvegel on May 24, 2007, 11:42:43
Weeping when it's upside down?
Sorry, couldn't resist.
