W113 Pagoda SL Group => General Discussion => Topic started by: paults1 on May 01, 2007, 18:27:03
Title: Fuel Injection pump oil capacity
Post by: paults1 on May 01, 2007, 18:27:03
I have searced the forums and have found the oil capacity for the early F/I pump mentioned anywhere from 180ml, too 250ml & 300ml. Which is correct? The manuals I have do not give the capacity for this early F/I pump. The dip stick is diffuclt to read because of the clear oil. It appears to be at the full mark. I know that to drain the oil you must suck it out from the dip stick opening & not the fill hole. I ask about this capacity because my pump leaks oil & I can't tell where the leak comes from. It appears it is comming from the very botton of the pump but not sure. Is there a gasket on the bottom of the pump? There is no oil leaking from the rear area of the pump where the govener adjusting screw is.
Regards, Paul '63 230SL
Title: Re: Fuel Injection pump oil capacity
Post by: hands_aus on May 02, 2007, 06:03:15
Hey Paul,
When I change the oil in my Inj Pump, I add about 150-180ml and then run the engine and check the level.
Generally I run my oil level at about halfway up the dip stick.
I monitor the level closely because I think there is a leak of the internal oil seal. However the level has not changed recently. I put that down to the fact that I have been using the car quite regularly.
Is it possible that the side cover seal is leaking?
Post by: JPMOSE on May 03, 2007, 05:19:15
Make sure you screw the dip stick in completely for measurement of oil level.  Otherwise, you will overfill it.
Best Regards,
J. P. Mose
1968 250SL
1987 560SL
