W113 Pagoda SL Group => General Discussion => Topic started by: wodan on August 04, 2006, 01:52:08
Title: indicators dont work..help
Post by: wodan on August 04, 2006, 01:52:08
Hi
could anyone tell me where abouts the indicator relays are situated in the car..im getting voltage to the stalk...but no indicators  as yet...many thanks
Title: Re: indicators dont work..help
Post by: Naj ✝︎ on August 04, 2006, 07:37:22
Wodan
Under the dash on the drivers side, on a black bracket. Indicator stalk connector plug on same plate
Post by: rob walker on August 04, 2006, 09:46:29
Unfortunately, if its the relay, then the old model is no longer available in the UK at least, you have to get a more modern unit from MB and do a bit of rewiring.
Rob Walker
2004 230 SLK silver
Post by: wodan on August 04, 2006, 14:08:37
cheers lads...found said relay..."blinkgeber" written on it..should have known really....but  alas there are no wires attatched to it...
should have known this would be  a bit tricky..seeing as this car has got a diesel engine in it....??...
Americans what are you like!
Post by: hands_aus on August 07, 2006, 05:40:11
Diesel?
mmmmmm
Maybe you could tell us more about your car?
It sounds interesting.
