W113 Pagoda SL Group => General Discussion => Topic started by: Rocket on July 27, 2006, 11:55:07
Can anyone advise whether there is supposed to be a pad, seal or packing between the Windshield Pillar rail and the Pillar or is it mounted metal to metal. There is a small pad at the top which fills an indent which I have but nothing along the whole length. The parts manual (item 90) doesn't make it very clear.
For clarity I am referring to the rail in which the door window seal between the pillar and the window is mounted. When I removed the rail it had been sandwiched with mastic.
Thanks in advance
Rocket.
230SL 1965
No packing/sealing on my 230 either ;)
When I removed mine it had glue that looks like carpenters caulk, just like the stuff they use in heavy doses when installing the chrome alone the leading edge of the hardtop.
Michael L. Hund
