W113 Pagoda SL Group => General Discussion => Topic started by: rwaw on July 09, 2003, 13:54:29
Title: Red Coil
Post by: rwaw on July 09, 2003, 13:54:29
Have just installed original Bosch red ignition coil (Bosch nr 0221 119030; MB nr 000 158 26 03) and correct ballast resistor at 1.8 kOhm.
Do the experts know if after this any further adjustments to timing/dwell etc need to be made ?
Thanks for your help.
Title: Re: Red Coil
Post by: Naj ✝︎ on July 09, 2003, 15:51:09
Raoul
No changes as far as I know.
Has it made any discernable difference in your opinion?
'Kloines Scheisserle'
Title: Re: Red Coil
Post by: rwaw on July 09, 2003, 16:08:29
Naj,
Have only driven for 10min today since fitting the red coil, but so far there seems to be no difference at all :( .
Must say it looks great though (!), shiny red.Still need to check the air filter on injection pump when warm........always something else to do.
Raoul.
Title: Re: Red Coil
Post by: Naj ✝︎ on July 10, 2003, 01:43:47
Raoul,
Is it shiny red or shiny ally with red label?
The filter can be a pain to remove as the heater return hose has to come off first. I would warm up the car first and remove the hose to the csv from the inj pump and block it with a 12mm bolt. Then fit another hose to the inj pump adaptor, start the engine and see if you can suck/blow thru that hose.
Title: Re: Red Coil
Post by: rwaw on July 10, 2003, 14:14:22
Naj,
Definitely shiny red;came in original Bosch-box.
Raoul.
Title: Re: Red Coil
Post by: Chad on December 13, 2005, 22:42:47
Does performance difference show up if you widen the sparking gaps some after fitting the red coil??
