W113 Pagoda SL Group => General Discussion => Topic started by: mrfatboy on September 25, 2005, 18:19:50
My 280sl engine is filthy. In the pass, I have had a pro steamer clean it. Recently, I bought a pressure washer 1650psi for doing everyday household stuff. Can I use the pressure washer maybe in combo with a decreaser?
my opinion is simple green, a soft brush and a slow rinse.... i wouldn't run the pressure washer in the engine compartment.... why push all that pressurized water where you don't want it? cover distributor, coil, relays and fuse box with plastic bags - i'm guessing you'll get most of the dirt out this way and not risk water damage to electrics and linkages...
Bob Happe
Pittsburgh, Pa
Let the Search Feature of this forum be your friend. ;) Simply entering "engine cleaning" turned up this thread that answers the question best...
http://sl113.org/forums/index.php?topic=3328+cleaning
1973 911S
2004 A4 3.0
2006 GS430
