W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: CJHenderson on September 10, 2025, 16:33:17
The hose attached to the front of crank case, where does it connect to?
I think that tube comes from the plastic fuel evaporation tank in the trunk which vents the fuel tank. Directs fuel vapor from the gas tank back into the engine - so part of the emissions control. This setup started in 1970 and replaced the "atmospheric" venting setup in earlier cars.
Thank you for your reply, your advice helped me greatly.
