W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: Federico82 on June 18, 2025, 15:26:05
Title: Looking for MB tex (red?) for a W113 of 1964 + sunvisors (ivory?) OEM quality
Post by: Federico82 on June 18, 2025, 15:26:05
I just bought a restored W113 but I am trying to correct all the mistakes made during the restoration. Can you give me the references of some suppliers who can provide me with the products in question? I am not sure about the interior color, so I am attaching a photo. Thanks
Title: Re: Looking for MB tex (red?) for a W113 of 1964 + sun visors (ivory?) OEM quality
Post by: Jack the Knife on June 18, 2025, 15:32:29
Tough deal on the sun visors, I have tried no less than five suppliers since making a thread on this late last year. The most acceptable have been from this company in Belgium: https://www.ebay.com/str/vwbtrading
There are a few suppliers from Turkey that all are using the same source and those visors look/feel like cardboard with a thin layer of upholstery. That's Bamboli and others that you'll see around. A shame, since they get the heat sealing perfect. I still have my original messed up visors, and the originals had some of that coconut husk-type material inside as well as a thin layer of something else, like a foam. They were puffier than what you can find. Lots of threads on here about sun visors. And we're not the only ones with this issue. BMW guys, Ferrari guys, basically everyone has an issue finding "correct" heat-sealed visors. I am shocked that there is not a company doing this well.
As for your seat upholstery, what is the color code on your data card?
Post by: Federico82 on June 18, 2025, 15:45:47
Thank you for your prompt response. I have already purchased from both Niemoller and Bamboli, but I returned both products. I agree with the quality of Bamboli, excellent welding but little substance in terms of content. Niemoller is better but the batch I purchased had a manufacturing defect.
As far as the color code is concerned, here my production card, could it be red 2500? See this link: https://palmbeachclassics.com/upholstery-codes/
Post by: Federico82 on June 18, 2025, 16:01:49
Here are detailed pic of my W113: https://www.italheritage.com/italian-cars-collection/mercedes-benz-230sl
I bought it last April and I'm still trying to fix all the mistakes made during the restoration. I've already had the mechanics checked, which are now ok but I'm having problems with the float in the petrol tank which doesn't indicate the petrol level correctly.
Next week the car will go to the body shop for some touch-ups, in particular on the front grille: the battery cover has been improperly painted in the body color and will need to be restored to black.
Post by: BobH on June 18, 2025, 16:24:18
...I'm having problems with the float in the petrol tank which doesn't indicate the petrol level correctly...
Hello, your car should have the early type fuel sender, with an external float.  If a later sender, with an internal float has been fitted, without a matching gauge, then your fuel level readings won't be accurate, the sender and gauge need to match
Post by: Federico82 on June 18, 2025, 16:52:24
Thank you for your message. I am trying to understand what type of float they mounted, I think this is the correct one but I don't know if this is exactly what was mounted on my car
Post by: BobH on June 18, 2025, 17:09:08
That's the correct one, i think these were hard to source at one time, but both types seem to be available now, so they should have been able to fit the correct one.  Can't think what else would cause a gauge to misread, not that these gauges are very accurate at the best of times.  Is it the original gauge do you know?
Post by: Federico82 on June 18, 2025, 17:58:20
This is not the original one but it is also available the original one, it is about price. Anyway I guess they use the wrong one on my w113, next days I will check and in case make a complaint.
Post by: Jack the Knife on June 18, 2025, 18:28:25
Yes, you're 117, or red 2500. I liked my dealings with KHM very much, and they're in Europe, so I'd just ask them. That said, what exactly is wrong with your upholstery? It looks pretty nice, at least from where I sit 5000 miles away.
Post by: Federico82 on June 18, 2025, 20:56:17
Thanks. I took a look at their website and they just offer leather, no MB tex. Anyway, I will write them.  My upholstery is ok, I just need some piece of tex to make some restoration next to the part where the sun visors are fixed.
Post by: BobH on June 18, 2025, 21:22:15
Don't know if these are any good, they have a website, but the dark red isn't shown, they might be worth a try
Or else Colin Ferns in the UK may know of a supplier
https://www.ebay.co.uk/itm/386305222256?chn=ps&norover=1&mkevt=1&mkrid=710-153316-527457-8&mkcid=2&itemid=386305222256&targetid=4584963496824971&device=c&mktype=&googleloc=133133&poi=&campaignid=555133857&mkgroupid=1301822921405862&rlsatarget=pla-4584963496824971&abcId=10053750&merchantid=87779&msclkid=6bd47de339701e40e03015b012245bd4
www.colinferns.com
Post by: Federico82 on June 19, 2025, 07:40:25
Thanks, I have already purchased this product and unfortunately the color does not match!
Post by: Federico82 on June 19, 2025, 07:45:02
I confirm that they installed the original one produced by Mercedes for the first series of the w113. However, the gauge rod continues to oscillate. Do you know if there should be bulkheads inside the tank, around the float? The mechanic told me that the problem could be due to the absence of bulkheads, but it seems strange to me because the accessories sheet does not provide for bulkheads even if they could be pre-installed inside the tank
Post by: BobH on June 19, 2025, 08:41:26
I'm not sure what you mean by bulkheads in the fuel tank, the tanks are standard, there are no accessories available, they are built with everything required already in them
If your gauge needle oscillates, or flickers, and it bothers you, i think this is quote common with the early floats, perhaps prompting the change to the integral floats.  There is a fix, although i've never needed to try it
Have a look on here, you may need to register as a full member to access this part of the manual
https://www.sl113.org/wiki/Fuel/SenderUnit
Post by: Federico82 on June 19, 2025, 10:04:16
Thanks, it is now clear to me. So I paid for a new float/sender that I do not need :P
Post by: BobH on June 19, 2025, 10:17:46
Looks like you might struggle to get an exact match, perhaps consider dying the new vinyl, especially if it's only a small area that needs patching, have a look on here for suggestions
https://www.sl113.org/forums/index.php?topic=25288.msg180833#msg180833
Post by: Federico82 on June 19, 2025, 14:55:58
Exactly I'm having trouble getting an exact match. I hadn't thought about painting the damaged part to replace. I'm waiting for samples, if I don't get an exact match I'll proceed as you suggested. I had already thought about having the vinyl insert on the ashtray painted, which I only found in black. Thanks
Post by: Federico82 on June 23, 2025, 11:56:56
What do you think about this?
https://www.sls-hh-shop.de/en/mercedes-230-280sl-w113/81-mirrors-sunvisors-int-ext-eqmt/sunvisor-67-rho-bracket-cream-281132
Post by: zoegrlh on June 24, 2025, 11:30:07
I when I did my restoration I bought sunvisors from Mercedes Benz Classic. They are expensive but are the “true” replacement, and the correct color.
Post by: Federico82 on June 24, 2025, 12:25:16
Thanks, are the original sun visors welded or sewn?
Post by: Federico82 on June 24, 2025, 12:57:13
I finally got an exact match!
Post by: BobH on June 24, 2025, 14:26:11
Welded, there's a write up in the tech manual where someone rebuilt theirs
Where did you source the material? it would be good to share with other members
Post by: zoegrlh on June 24, 2025, 16:15:09
Great match. Way to go. 👍
Post by: Federico82 on June 24, 2025, 16:33:58
I sourced the material in Italy, here the link to the tex: https://interniauto.eu/ecopelle/ecopelle-auto/ecopelle-bordeaux-al-metro
Unfortunately they have the plain only, no basketweave vinyl inserts
Title: Re: Looking for MB tex (red?) for a W113 of 1964 + sunvisors (ivory?) OEM quality
Post by: Federico82 on June 26, 2025, 08:26:43
What do you think about these sunvisors ? These appear to be the best sunvisors available online:
SLS (hand sewn??? Which I believe to be incorrect)
https://www.sls-hh-shop.de/en/mercedes-230-280sl-w113/81-mirrors-sunvisors-int-ext-eqmt/sunvisor-67-lho-bracket-cream-281131
SLS (heat-sealed)
https://www.sls-hh-shop.de/en/mercedes-230-280sl-w113/67-windscreen-230sl-250sl-280sl/pair-sunvisors-230sl-light-repro-281730
CLASSIC MERCEDES PARTS (heat-sealed)
https://classic-mercedes-parts.com/en/w113-interior/sun-visor-set-w113-230sl-pagoda-lhd.html
SL SERVICE (heat-sealed)
https://shop.slservice.fr/pare-brise/5623-pare-soleil-droit-230-250sl-avant-nr-2979.html
https://shop.slservice.fr/miroirpare-soleilsigle/6257-pare-soleil-gauche-230-250sl-avant-nr-2979.html
SL SHOP (heat-sealed)
https://parts.theslshop.com/mercedes-benz-sl-w113-230-250-pagoda-rhd-creme-sun-visor-set/
Post by: zoegrlh on June 26, 2025, 10:46:50
Again I say go to MB Classic Center, Longbeach California. These will be the original reproduced product by Mercedes Benz. But if too pricey then go with a heat seal visor. Great looking sunvisors make you car pop.
Post by: Federico82 on June 26, 2025, 11:02:21
Thank you but I am based in Italy
Post by: rwmastel on June 27, 2025, 01:44:37
I don't think he means to literally travel there in person.  He means to research their product.  Email, ask for pictures.
Post by: zoegrlh on June 27, 2025, 22:46:49
Correct, they ship all over the world, or even go to your closest Mercedes Benz’s dealer as for parts supervisor, and have him order the Sunvisors for you and they will be shipped there. MB has a worldwide parts network. Most of my Pagoda parts were ordered by my local MB dealer.
Post by: Pawel66 on June 28, 2025, 19:05:28
Do they have them available? I see nothing there for for any W113...
Post by: zoegrlh on June 29, 2025, 19:16:28
You will need parts number: 113 810 07 10 for left, 113 810 08 10 for right. These are the original stock numbers. As do some of their parts, numbers get superseded by a newer number. However, the MB computer will give the newer numbers that link to the original numbers. Good luck, I’m sure that they have them. When I purchased my MBcA sunvisors, back cc 15+ years ago, the MB computer said there were only in worldwide inventory of 6 pairs, all on shelf in Germany. I did find out that when those other 4 pairs were sold, members could not get sunvisor replacements and we had a member living in London that contracted a company to China to fabricate look alike. They were really nice looking and were sewn from the inside. Color and all matched nicely. Since that time, some few years later, MB produced them again and they were available thru MB. So how MB can look those Sunvisors for you, and ship to a Mb dealer near you.
Post by: Pawel66 on June 29, 2025, 19:29:48
No harm to ask.
I see undefined availability, which usually means NLA. But who knows...
Yes, the numbers changed. They will see worldwide inventory, no issue there. In fact - any dealer is able to do it.
Let's see.
