W113 Pagoda SL Group => Research & Development => Topic started by: baon3h on June 08, 2025, 18:05:38
Title: Replacing brake booster with electronic assembly
Post by: baon3h on June 08, 2025, 18:05:38
I was wondering if anyone has looked into replacing the brake booster with a modern electronic assembly (such as the Bosch iBooster) that doesn't require a vacuum and runs on 12V. The iBooster is interesting because it runs without a CAN bus. You can find them used for less than USD 200 (including master cylinder).
Replacing the original brake booster is only getting more expensive and having a more affordable option would be great.
Title: Re: Replacing brake booster with electronic assembly
Post by: Jack the Knife on June 08, 2025, 19:23:46
That's an interesting idea. I'd contact this guy, who put one in his Volvo Amazon: https://www.evcreate.com/installing-the-ibooster/
It looks like he makes custom mounting kits for people, too. There is a popular YouTuber as well who put one in his gen-1 Hummer electric restomod build because the pump for the brakes was loud and whiny.
If you do this swap, please let us know!
Post by: Leester on June 09, 2025, 13:31:56
I've been exploring this for my 220SE cab with the remote brake booster. I would really like to keep it as original as possible but if the remote brake booster gives out, the cost to repair may be an issue. On top of that the current set up is a single circuit brake system seems outdated. My problem is that I (fortunately) have a manual transmission and the master cylindar for the transmission is right next to the brake MC affording little working space. This can be resolved with a newer pedal package with the clutch MC built into the clutch pedal but again, more work and expense.
Very interested in following anyone proceeding down this path.
Post by: baon3h on June 09, 2025, 17:05:15
I was afraid that someone would say I'm crazy ;D
I'll do some more research and then order the parts. It looks like the bolt pattern is close but not close enough so I'll have to design a custom bracket for the firewall. That seems doable. What I want to do next is measure the liquid displacement of the old booster when I press the brake pedal (without vacuum) to have a baseline to compare against. I'm not sure how different the stroke for the iBooster will be.
In terms of brake fluid, the OEMs recommend DOT4 for the iBooster. I assume the Mercedes recommended brake fluid was chosen to work with their brake master cylinder. What are your thoughts?
Post by: Jack the Knife on June 09, 2025, 17:30:05
I don't think anyone would fault you for wanting to have a safer car, and in my opinion, the spirit of this car is not in the brakes.
You can use DOT4 in the OEM system, many people do.
Post by: Leester on June 09, 2025, 23:31:35
Baon3h, do you have a manual shift car or automatic? I think your project will be easier with an automatic transmission since the clutch MC won't be in the way. Please keep us posted and good luck. Lee
Post by: baon3h on June 10, 2025, 00:27:03
Hi Leester, I have a manual but I'm not planning to change the pedal itself. The brake booster should bolt onto the firewall with an adapter. I only have the clutch reservoir next to the brake booster, there should be plenty of space.
I'm hoping that I will get the right amount of travel out of the existing brake pedal linkage to power the new booster. Am I being too optimistic?
Post by: Leester on June 10, 2025, 16:47:51
"Hi Leester, I have a manual but I'm not planning to change the pedal itself. The brake booster should bolt onto the firewall with an adapter. I only have the clutch reservoir next to the brake booster, there should be plenty of space."
Interesting - in my 63 I have both the clutch reservoir and the clutch MC next to brake booster. My "research" to date consists of looking at a couple of U-tube videos so I think you're deeper into this than I. I agree that you will have to fabricate an adapter and maybe that will resolve any clearance issues in the engine compartment.
"I'm hoping that I will get the right amount of travel out of the existing brake pedal linkage to power the new booster. Am I being too optimistic?"  I can't help you with that question. I'm almost always too optimistic about everything I undertake.
Good luck and obviously you have one follower and supporter.
Lee
Post by: baon3h on June 11, 2025, 15:31:22
And so it begins! The booster is a GEN2 from a Tesla Model Y and has about the same bolt pattern (square, 72mm). I hope that it will bolt on with minor modifications (probably a spacer).
Brake line ports are on the opposite side of the cylinder. I noticed that my cylinder has three outputs (I think 2 are common on a 280SL). I will get a splitter to hook up the front brake lines.
Next up, electrical test on the bench.
Post by: Jack the Knife on June 11, 2025, 18:03:38
It's nice to see someone immediately jump into R&D rather than admiring the issue. Looking forward to your progress
Post by: Leester on June 12, 2025, 14:27:07
Baon: Your picture suggests to me that your project just got easier. Your have a later model (post 1963) with the booster at the firewall. I have an early model with a remote booster behind the left side headlight.
That's why all you have for the clutch is the fluid reservoir - the clutch MC is built into the clutch pedal under the dash.
Your picture also shows the problem I would encounter. In my case, the clutch MC is just to the right (as seen from sitting in the driver's seat) of the brake booster. Your picture shows the electric brake booster with a chunk of its body that extends to the right which, I'm sure would interfere with the operation my clutch pedal and clutch MC.
All that said, I agree with JtK that its nice to see someone jump in and move on the project. You already have the dual circuit brake system so I might quibble with replacing the very common stock booster but hey, go for it!
I'll try to post a picture of my early single circuite brake system set up which will explain my concerns with converting my system to electric booster. Good luck with this project!  Lee
Post by: MikeSimon on June 12, 2025, 16:21:18
The power brakes run on vacuum. Many modern cars with turbo engines and CDI lack intake manifold vacuum ( the source for the brake booster) these cars have a secondary vacuum pump, driven by belt, directly from the camshaft or by electric motor. Wonder if this would make a possible conversion.
Post by: Leester on June 12, 2025, 23:07:52
Interesting point Mike. I would add diesels to your list (fondly recalling my 300SD). What both Baon and I are trying to do (albeit for different reasons) is eliminate the vacuum brake booster.
I will let Baon weigh in on what might work in his case. In my case, which is much different than his, I have the clutch push rod and brake booster push rod about three or four inches apart on the fire wall.  The only solution I have come up with to date is changeing the old style pedals in which the clutch pedal just pushes a rod through the firewall to the clutch MC over to the new style pedals in which the clutch MC is built into the clutch pedal. On the newer style pedals, as with I think all W113 cars, the only clutch equipment in the engine bay is the clutch fluid reservoir.
I'm trying to think of a way to use your suggestion but I keep bumping into that darn clutch push rod and MC in the engine bay. But I'll keep your suggestion in mind as I pursue options.
When I replied to Baon, I didn't realize he had the fire wall mounted booster and I thought we were both dealing with remote brake boosters.
I'll try to get a photo up tomorrow.
Post by: baon3h on June 12, 2025, 23:24:43
Quote
You can flip the master cylinder by 180 degrees on these so it might give you just enough space. Part numbers for the booster I have are 1188671-00-A and 1188671-00-B.
Post by: mauro12 on June 13, 2025, 09:32:25
Guys , my mechanic tested my brake booster with a vacuum gauge and at idle shows a vacuum of 500mmhg or 0.6 bar. He said it is still within specs. When you press the brakes , it goes down to 400mmhg or 0.5 bar . What is your assesment on that ? thank you
Post by: Raymond on June 13, 2025, 13:44:00
Baon, I'll be anxiously awaiting the results.  How will you address the fluid level sensors?
Post by: baon3h on June 16, 2025, 00:23:48
Hi Raymond, the reservoir has a two-pin sensor which seems to match the circuitry of the old sensor. If the fluid level is low, the circuit closes and the light turns on (see picture).
I just flushed the cylinder and was able to run the fluid displacement test. The bore seems to be significantly bigger. I estimate that I need only half the pedal travel at twice the force to get the same displacement of fluid. That's not great if I want to bring the car to a stop in case I have an electrical failure and no boost.
I think there are two options, keep the original master cylinder (it should fit with an adapter), or change the pivot point on the firewall to get extra leverage.
Post by: baon3h on June 18, 2025, 15:46:46
Things are progressing nicely. I've decided to use the original master cylinder. I won't have to bleed my brakes and all I need is an adapter plate. I designed it in CAD and it's being laser cut. Hopefully receiving it by next week. I also designed an adapter for the push rod to connect to the brake eye bolt on the firewall.
The booster just slides into the mount on the firewall. It's a near-perfect fit without any modifications.
Post by: clunker on June 18, 2025, 15:52:44
Nice. Which fabrication service do you use?
Post by: baon3h on June 18, 2025, 16:12:23
I'm using onshape for CAD and sendcutsend.com for laser cutting. Trying to find a local shop but sendcutsend is just amazing by providing very detailed instructions and their fabrication limitations (bend radii, etc.).
Post by: Leester on June 18, 2025, 22:41:07
Looking good. Keep up the good work!
Post by: clunker on June 20, 2025, 14:41:59
Agree sendcutsend is great - just wondered if they also included the stand offs on you adapter late as well
Post by: baon3h on June 28, 2025, 00:35:27
They did! The M8 bolts are inserts from sendcutsend. They are perfectly flush with the surface.
The parts finally arrived. Unfortunately, they were not able to bend my Y-fork for the booster rod end. I came up with two alternatives: A 12mm clevis pin for the rod end that came with the booster, and a DIN 71752 rod end with a nylon bushing (see picture). I'll probably go with the DIN rod end as it is more compact which allows me to remove one of the aluminum plates from the booster.
I started wiring up the car but came across some exposed copper in my harness. So that will need to get fixed first. While I'm at it, I will add a 10 gauge wire to the battery, ground and a smaller wire from the ignition. I'll keep you posted!
Post by: baon3h on June 30, 2025, 21:30:38
It's done! The booster is installed, and all wired up. I did a quick brake test in the garage and then a test drive. I can confirm the general sentiment from others who have done the swap. The brake pedal feels very responsive, there is no lag in activation by the booster. Made several safety stops and checked for leaks. I also ran it without power to the booster. The spring in the new booster is slightly stronger so it requires a little more pressure but I was able to lock the tires without any problems.
I'm planning to do a longer write-up of this process. Going with the W113 master cylinder definitely made the swap an afternoon activity (once you have all the parts). I'm so glad I didn't have to bleed the brakes for this.
I will probably redesign the adapter plate to be a little thicker (.500" instead of .375"). I couldn't detect any stress or bending during operation but it always better to be on the safe side.
Cost breakdown (without tax and shipping):
* Booster $175
* Booster Wiring Kit $40
* Adapter Plate $30
* Three Aluminum Spacers $30
* Y Fork with Clevis Pin and Bushing $15
* Wires, fuses, heat shrink
Let's call it an even $300.
Post by: clunker on June 30, 2025, 23:03:58
Excellent, great job.
Post by: Jack the Knife on June 30, 2025, 23:17:53
I'm extremely impressed at the speed of this. Is there any noticeable effect in stopping distances?
Post by: baon3h on June 30, 2025, 23:31:54
I want to put the car on a roller brake test to get reliable measurements.
The car never had a working vacuum booster as far as I can tell. It was leaking air, causing the engine to run rough when I pressed the brake pedal. So I don't really have a comparison.
Thanks everyone for the encouragement to go through with this. I probably wouldn't have done it if wasn't for the support I got here.
Post by: Leester on July 01, 2025, 12:07:53
Well Done.
