W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: dsbanfield22 on May 26, 2025, 12:17:29
Title: Recommended carpet glue
Post by: dsbanfield22 on May 26, 2025, 12:17:29
I would appreciate a recommendation for glue to use to reattach my carpet in the luggage/package area.  Thanks!
Title: Re: Recommended carpet glue
Post by: Jonny B on May 26, 2025, 13:16:19
When my buddy and I installed new carpet in his 250 SL, we used a DAP product called Weldwood. The product in the red-bottomed can is what we recommend. You may need to get creative to get some, as it is a solvent based formula. We were able to find in SoCal, but we did have to search around.
Post by: zoegrlh on May 26, 2025, 14:24:59
I have used Weldwood glue too. Also 3M makes a good glue that is in spray can.
Post by: kampala on May 26, 2025, 16:42:15
DAP Weldwood Contact Adhesive Top & Trim HHR Solvent
Post by: Jonny B on May 26, 2025, 19:01:31
We did use some of the 3M glue, but found that the Weldwood was better for the bent and curved areas.
Post by: GM on May 26, 2025, 19:08:43
Go for the heat-resistant and water-resistant variety
https://www.grainger.com/product/10L520 (https://www.grainger.com/product/10L520)
https://www.grainger.com/product/5E094 (https://www.grainger.com/product/5E094)
Post by: Cees Klumper on May 26, 2025, 19:55:10
x3 on the Weldwood Landau Top & Trim HHR Solvent Type Spray Grade Contact Adhesive. After I did a bunch of research, found this was what many professional upholstery shops use - I used it to replace the headliner on my Bronco II and it came out perfect:
https://www.amazon.com/Dap-Weldwood-Contact-Adhesive-Solvent/dp/B004IH3HAQ
Post by: dsbanfield22 on May 26, 2025, 22:58:36
My sincere thanks to all... will try the Weldwood and will post "after" photos.
