W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: sens on May 18, 2025, 20:41:39
Title: Fuel Injection Pump
Post by: sens on May 18, 2025, 20:41:39
Hello Pagode friends,
I hope you can help me with an issue I have quite some time now...
My European 280 engine starts and idles fine, however when driving the car I have 3 issues (especially at full operating temperature):
- some popping after throttle release
- some grey smoke in combination with the popping
- at higher speed (> 80km/h) some minor hesitating (sputtering) of the engine; not much, but noticable.
Some facts:
Engine overhauled about 1000 km ago.
New injectors, tested.
123 ignition is set correctly.
valve clearance is set correctly.
spark plugs are slightly braun.
Another important fact:
I bought the 250SL with a 280 block which is combined with the original FIP for an 250SL: PES 6KL 70A120 R18Z
The official model for a 280 SL block however is an: PES 6 KL 70B 120 R21
So my question is: could this "mismatch" between block and FIP be the reason of the issues I have.
What would be your advise?
Thanks a lot!!!
Halvor
Title: Re: Fuel Injection Pump
Post by: MikeSimon on May 19, 2025, 14:56:19
What head to you have on your 280 block? The R21 is not the only FIP for a M130-983.
Post by: sens on May 19, 2025, 15:14:15
Thanks for your reply!
On the head it says:
130.016 000 1
See picture
And indeed, the block is M130-983
Halvor Sens
Post by: sens on May 21, 2025, 17:29:12
I think for EU cars the possible FIP’s are R 21, R23, R25, right??
Post by: Cees Klumper on May 21, 2025, 18:26:11
Hi Halvor - I am not an expert on the FI system by any means, but my guess would be that a 'mismatch' of this nature should not be causing the symptoms you are experiencing. I would look more into something like a vacuum leak, too rich adjustment of the FI pump, stuck pistons inside the pump or the rack not moving freely, that sort of issue.
Post by: sens on May 21, 2025, 18:38:52
Thanks for your reply Cees!
In the mean time I called a FIP expert and he told me it could cause the symptoms, but not sure…
He said that the slight hesitating at higher throttle could be caused by the fact that the 250 pump does not deliver enough fuel for the 280 engine.
I checked the vacuum with a smoke test; looks ok.
I also tried to make the mixture leaner but that makes thing worse: more hesitating at higher speeds.
I think the rack moves freely, because there is a perfect respons on the throttle. Idle is good.
Could I check the things you mentioned by opening the side cover of the pump?
Should I take the pump out to investigate?
Post by: Jack the Knife on May 21, 2025, 22:55:01
Not to start a goose chase, but when I was disassembling everything, the inside of my throttle body was so encrusted with crap that it looked like a decades-old uncleaned charcoal grill in a public park. Yet, surprisingly, it still moved freely. But was all this cleaned when the engine was rebuilt? Maybe some encrustation in there delaying throttle response?
Is the popping in the engine or the exhaust?
Is there any way you can upload a top-down view of the engine bay?
Post by: Cees Klumper on May 22, 2025, 12:32:18
"I also tried to make the mixture leaner but that makes thing worse: more hesitating at higher speeds."
Have you tried making the mixture richer?
Although that could cause more grey smoke, unburnt fuel?
Have you tried checking the CO level? Not sure whether simple testers like the Gunson can do that at higher revs, I've only used mine to set CO level at idle.
There are adjustment screws for the various rpm ranges on the pump but experts always say not to touch those.
Perhaps having the pump bench tested by a shop with the proper Bosch setup/calibration machine would be a good idea. At one point, I remember Van Dijk in Lisserbroek had such a machine.
Post by: sens on May 22, 2025, 12:42:06
Thanks Cees!
I will follow your suggestions (make the mixture slightly richer) and see an expert to see what happens.
I'll report back!
Halvor
Post by: sens on May 22, 2025, 19:35:09
Hi Jack!
Yes, I looked into the throttle body and it is clean.
Popping is comming from the exhaust, together with a small grey smoke puff when I release the throttle.
Attached some pictures of the engine bay.
Cheers!
Halvor
Post by: Pawel66 on May 22, 2025, 19:58:05
I am not a mechanic, but:
Is your vacuum line connected?
If this thick rubber hose is the vacuum line - I am not sure if it is the right type of hose for a vacuum line... Maybe try a correct one?
There is clearly tension applied to ignition leads - they are too short. This tension is pulling connectors and distributor cap. I would sort it out...
There are several wires coming to coil connector - is it not too many?
Post by: sens on May 22, 2025, 20:54:45
All very fair comments Pawel! Thanks!
It shows the power of a picture...
The vacuum line goes on my 123-distributor and reduces its diameter just before the throttle body. Probably not original, but no leaks...
The tension on the spark leads is too high, I agree. I will change that. Easy fix!
My 123-ignition has long wires and I decided not to cut them yet, so that confuses when you look at the picture. Well spotted. I attached another picture.
Thanks again for your comments!
Post by: Jack the Knife on May 22, 2025, 21:12:17
Could you measure the internal diameter of this vacuum line before the diameter is reduced?
Post by: sens on May 22, 2025, 21:46:32
Certainly!
I just measured 4.5 mm internal diameter; the connection tube on the 123 ignition  5 mm.
I think that is OK; no leaks.
Post by: Jack the Knife on May 22, 2025, 22:11:21
https://www.authenticclassics.com/Distributor-Vacuum-Line-Mercedes-230SL-250SL-280SL-p/auth-005108.htm
The internal diameter of this line I have here (white vacuum line) is 1.5mm. External is 3.75mm. I am not a mechanic, so I don't really know the interaction this line has, but it might be wise to have the right line. You don't have to buy this one from Authentic Classics -- I didn't -- look at the part number in the kit and order everything separately from autohausaz to save quite a bit of money.
Post by: Pawel66 on May 23, 2025, 03:20:55
At Mercedes:
vacuum line A 000 158 14 35
rubber sleeve connectors A 117 997 09 82
I do not think this alone is a culprit, it is more about general clean up...
Post by: Peter h on May 23, 2025, 04:04:32
I'd check the basic settings. It doesn't look right to me, but I could be wrong.
Post by: sens on May 23, 2025, 06:33:50
Yes, I agree.
There is no flow through that line, just vacuum, so diameter is not so important.
Thanks and again, well spotted!
Halvor
Post by: sens on May 23, 2025, 06:38:12
Wow!
You guys are detectives!!!
It looks like the two arms are parallel, but that is vaused by the angle of the camera.
Attached another picture where the throttle is partly open to have a better view.
I think it is OK.
Thanks!
Halvor
Post by: Peter h on May 23, 2025, 09:04:15
I would also first route the ignition cables and wires correctly. What engine is installed? It could be that certain components don't belong together. I think you should check everything first. The surprises on these cars never end, but that's the fun. Peter
Post by: sens on May 23, 2025, 09:22:29
Yes Peter, you are right.
Engine and FIP don’t belong together.
But is that a real problem?
Post by: rosch on May 25, 2025, 12:38:48
Generally  a good running engine needs air and fuel in a right mixture and a correct timed ignition.
Here are just some thoughts :
 -The 123 ignition may cause some light popping at throtthle release , this seems to be normal behavior and is reported by many users.
-Popping in the exhaust accompanied with grey smoke  however may indicate unburnt fuel in the exhaustsystem. This , together with your slight hesitating ,may be pointing to :
1.a fuel/mixture problem in general or - I had the same experience - a leaking injector causing uncontrolled /erratic fuel supply to a specific cylinder , resulting in the same syptoms you have.
A simple check with a "Colortune" ( just google it) helped me find the culprit and also made fuel adjustments easy ,even at higher rpm's
2. an ignition problem  think of wiring ,caps ,wrong or damaged sparkplugs ( check for thin cracks/black traces at the insulator)
If you like to enrich your mixture as a first  try-out,then just add a thin washer underneat the baro compensator.
You may also read my mini serie of postings about "230SL bad starting and running problems".A lot applies to your car as well.
Good luck !
Post by: sens on May 25, 2025, 20:10:11
Hello Rosch!
So nice to get a good comment from somebody living next door! Almost...
I fully agree with your remarks:
-The 123 ignition might cause some light popping. Could be. I do have a Crane transistor ignition which I used for my MGA. I read some positive comments about that. I could mount it on my Pagode and see what the effect will be.
1a. A year ago I bought 6 new injectors. Last week I tested all of them with an injector tester and indeed one of them looked more like my wife watering the plants in the garden. I replaced it by a new one and that was a lot better.
I looked at the color of the spark plugs and the color of the injectors (No4 from left) to find the problem. (see picture) The spark plug is fully fouled and the injector has no discoloration like all the others, indicating a very bad combustion, I would say.
After your experience about the Colortune I was going to buy one, but I remembered I had one for my previous car. And surprise... it has the same size and is brand new, I never used it. I will definitely use it in the near future!!!
2. Spark plugs are relatively new; so is the wiring. I think ignition timing is set correctly. I checked yesterday.
I always thought that popping in the exhaust meant the mixture was little rich. But I just read on this forum it is just the opposite!!! Mixture is too lean.
Also the little hesitating at full throttle indicates a lean mixture.
So I just did what you suggested and added a 0,1 mm washer underneath the barometric compensator.
I will have a test drive tomorrow and come back with my findings.
In the mean time I will study your postings!
Thanks for all your suggestions!!
Halvor, Drunen
Post by: sens on May 26, 2025, 16:53:34
I took the car for a ride this morning.
It runs more or less OK, but still some popping at throttle release; maybe a bit less.
I did the Colortune test like I show in the first video.
I would say adding 0.1 mm washer (total 2.2 mm)  under the BC makes the engine run richer; I would say too rich.
I removed the 0.1 washer and took a video at idle.
Still rich I think, however CO looks OK. (not calibrated)
As a next test, I could put the Crane ignition on the car just to see if there is any difference.
What do you think?
Post by: Cees Klumper on May 26, 2025, 19:58:29
I don't expect changing the ignition will make a difference - unless the 123 ignition is somehow faulty and needs to be replaced.
Still would be good to test the CO level, maybe at your local APK station you can ask them to check it?
Post by: sens on May 26, 2025, 20:59:15
Yes Cees,
I know my local workshop pretty well and he could help me calibrating the old Bosch CO meter!
Halvor
Post by: mauro12 on June 18, 2025, 13:59:46
Hi !i have a similar situation but at the opposite site. i have a 250sl with original engine but my injection pump has been replaced probably by the previous owners ( i dont know why and when ). The pump i've got is the r22 , which is typical of a 280se car. 2 years ago i sent the pump for a complete overhaul becauase the car was running very rich ( i sent to hans fritszche in germany , oldtimer technik) . He replaced the space cam with the correct cam of an r18 pump and set my pump accoriding to the r18 configuration. The result is perfect . He suggested me to replace the injectors too but i had a bad experience with r2 injectors ( you can read in the forum if you want ). i have a popping sound when i release the accelerator too , but i guess is something wrong with the exhaust or a small leak near that .
i bought from mbclassic.de a set of new r2 injectors and they were not working at all and i've been refunded. I decided to keep my old r1 for the moment . They release the fuel a bit too early but still within the specs.
Post by: sens on June 18, 2025, 14:51:49
Thanks for your comment Mauro!
My FIP is at the workshop actually and specialist will tune it at the correct specs for a 280 SL engine.
I will let you know what the result will be!
Halvor
Post by: sens on July 18, 2025, 18:58:50
Hello!
The FIP is adjusted for a M130 engine now.
It was still a bit rich in the beginning, but after removing a shimm under the Barometric Compensator (half a turn) things got a lot better.
Colortune gives me a more or less blue combustion flame.
No more popping, no hesitation when accelerating, power feels great!
I think the FIP is realy well adjustied and the car drives very well!
Thanks for all the support!
Halvor
Post by: rwmastel on July 18, 2025, 20:08:42
Hoooray!!  Congratulations.   :)
Post by: thomasw on July 19, 2025, 08:52:35
On the first picture it looks like you are missing the cap over the axle for the air inlet. This cap has a paper gasket. I guess it will draw in air there.
Post by: sens on July 19, 2025, 09:03:10
Thank you!
It was quite a jouney, but I am very happy with the result!!
Special “thank you” to my allmost neighbour Rosch who gave me a lot of very useful advice!
Post by: sens on July 19, 2025, 09:11:06
Thanks Sweden for your comment!
Can you explain more in detail what cap you mean?
Thanks!
Post by: thomasw on July 19, 2025, 09:36:20
Thanks!
This photo is from my M127 engine, if yours has the same look i guess you are missing this cap = cover.
Post by: sens on July 19, 2025, 10:08:40
I see!
See picture.
You are absolutely right!
Never noticed that something was missing here.
I’ll try to find one.
Thanks for your observation!
Halvor
Post by: Pawel66 on July 19, 2025, 11:17:38
If the car is automatic, there is a switch in this place that controls the shifting. If it is manual, there is a gasket and cover. The cover is available at SLS-HH shop.
Post by: sens on July 19, 2025, 14:27:54
Indeed, I found the part.
But also this statement on the forum:
Re: Throttle body butterfly axle cap?
Pete Lesler wrote:
The 280's did not have this cover. only the 230 and 250.
I have an early  factory photo of a 280SL which clearly shows this cover is missing.  I challenged an owner of a 1969 280SL with manual trans at Legends of the Autobahn as his throttle housing was missing the coverr.  We researched it and have determined that it was left off the manual trans 280SL's.
Pete Lesler
W113SL
So maybe it was never there...
I have a smoke device to look for air leaks.
If there is no leak, I will leave it as is.
Thanks again,
Halvor
Post by: thomasw on July 20, 2025, 08:41:01
Pete Lesler
W113SL
Thanks again,
Halvor
Yes, it looks like that. Probarly some cost saving as most of the 280 has automatic gear.
Post by: Pawel66 on July 20, 2025, 09:04:43
I came across manual cats with switch installed on the throttle…
In any case, the cover makes sense to prevent dust coming in and air leaks, I think.
Post by: Taleb on July 20, 2025, 13:05:38
halvor,
don't waist your time , just contact this specialist  https://www.koller.de/
good luck
