W113 Pagoda SL Group => Items for Sale => Topic started by: Crobitaille1959 on January 27, 2025, 22:47:40
All,
For sale below, Please PM me for pictures of any parts you are interested in. All were removed from a "Barn Find" 1969 280SL that I'm restoring with an engine swap. Engine and 4-speed transmission are already sold. All OEM parts I'm open to reasonable offers. You'll pay the freight actual cost.
Starter, tested and working $125 obo
Alternator, complete with mounting bracket and hardware $250 obo
Fuel Injection Pump, turns by hand $450 obo
Rear Exhaust manifold, no cracks, with all bolts $200 obo
Front exhaust manifold no cracks $200 obo
Intake Manifold, no cracks $400 obo
"Loop" brackets and bolts that attach to oil pan that secure Starter Cable and other electrical wires $50 obo
Fuel Injectors [6] $300 obo
Gas Filter housing $75 obo
Fuel Pressure regulator $75 obo
Distributor with all leads $350 obo
Water Pump [and bolts[ $100 obo
Motor mount [with OE Bolts, bottom section, R & L, $100 obo
Motor mount brackets that attach to Block [with bolts] OEM 1272231104 & 1272231204. $300 obo
Steering Wheel, Black [no cracks] with Chrome ring. Pad must be replaced, $200 obo
Complete throttle linkage assembly, all parts, pivots and brackets $400 obo
Thermostat housing $75 obo
Fuel Injection lines, complete $350 obo
Fan Pulley $75 obo
Crankshaft Pulley w/Balancer and all bolts $400 obo
Fan w/clutch $75 obo
Aluminum Heat shield, fair condition $100 obo
Thanks to all
checking to see if the alternator is 55AMP or 35AMP. Also since you are swapping your engine out, I wanted to check if you have a fan shroud that you are wanting to sell for a 280SL.
Mark
35 Amp. Part number 0 120 400 606
