W113 Pagoda SL Group => Electrical and Instruments => Topic started by: JayP on December 18, 2024, 18:52:12
Title: Mysterious Yellow Wire
Post by: JayP on December 18, 2024, 18:52:12
HI, I'm trying to identify a yellow wire that passes through the firewall above the passenger side footwell. It has an in-line fuse on the side inside the car. There was a previous post (https://www.sl113.org/forums/index.php?topic=17749.0) with someone asking the same question about the same wire but no one identified it, so I'm asking again with the hope that someone might know. Thanks!
Title: Re: Mysterious Yellow Wire
Post by: BobH on December 18, 2024, 19:24:55
Hello, it isn't shown on the wiring schematics, and the fact it has an inline fuse would indicate it's been installed later, perhaps by a dealer
Have a look on here, seems Blaupunkt radios used a yellow power wire with inline fuse
https://www.sl113.org/forums/index.php?topic=2223.msg11714#msg11714
Post by: JayP on December 19, 2024, 00:19:55
Thanks very much for replying. I do have an old Becker radio but it's working fine without that wire. Also that wire travels through the firewall and forward into a wire bundle, not to a fuse box. Still stumped. I will test it to see if it's live.
Post by: clunker on December 19, 2024, 03:23:15
Was there a/c previously installed? this wire may have come from the under dash a/c unit to control the compressor clutch.
Post by: JayP on December 19, 2024, 21:30:10
Yes. According to the data card there was once a/c, although it's been without it for the 20 years I've owned the car so I forgot. That makes sense. Thank you.
