W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Philippe VIARD on October 25, 2024, 09:10:09
Title: tightening torque
Post by: Philippe VIARD on October 25, 2024, 09:10:09
Hello everybody,
What is the torque tightening of the 12 bolts of the gearbox support for a manual transmission?
Thank you for your answer
Title: Re: tightening torque
Post by: ja17 on October 25, 2024, 14:32:46
Be sure to clean and seal any bolts on the front and rear cover with sealant or they will leak transmission fluid since they enter into the gear box. They will leak transmission fluid if you do not.
Post by: Philippe VIARD on October 25, 2024, 16:03:36
Thank you ja17 for your answer but my question was about the trapezoidal plate under the gearbox held by 12 screws of 10mm diameter with a thread length of 20mm
