W113 Pagoda SL Group => Body, interior, paint, chrome, and cosmetic items => Topic started by: StevenF on September 26, 2024, 15:03:39
I found Gas cap and need your help determining if it is OEM--it has no box
All the reproductions I have seen have no star--that is why I am asking
BTW there are no numbers on the bottom of the piece
Please advise
Steven
Please show the key, both sides.
Most of the reproductions do not have logo. But the key and key profile will tell you the truth.
what should the key show?
Both the gas cap and key look identical to mine, bought from MB in 2016.
alpina, are there any words on the bottom of your gas cap?
Some units have words /numbers
https://www.authenticclassics.com/Chrome-Locking-Gas-Cap-late-type-p/auth-002476.htm
https://www.ebay.com/itm/195219956526
Also, is the 71 supposed to be vented or unvented?
I've started to see some "cheaper" caps with the star logo for sale recently, i wonder if someone has started to reproduce them. The originals normally sell for anything over £1K
If you haven't already, have a look on here
https://www.sl113.org/wiki/Fuel/LockingGasCap
Looks like there should be writing stamped on the underneath, with or without a key number
But, if the quality and price is ok, it could be a way of getting a decent cap without mortgaging the house
The key will show brand and profile. Aftermarket caps keys do not have original profiles.
This cap, if authentic (and it looks authentic) is for non-one-key car, that you can tell now.
These are the keys
is this OEM?
Also of note, there is no writing on the metal bottom of the cap....the OEM's I have seen always say something in German..
Please advise
Here's my cap and key that came with my SL. Serial number on key was blurred
Ymos. You are showing only one side, but looks like HF7, meaning code SR, KSR or TSR. Original cap IMHO, at least cylinder and chromed crown. I am basing this on never spotting aftermarket caps with old key profiles. I can be wrong, of course, but I once spent quite some time on that.
However: the shape of the hexagonal part at the bottom is different than those on the pictures - looks like you have a round element there, missing on others. It does, however, look like aftermarket one: https://www.niemoeller.de/en/w113/w113/B043/470/d47051b-filler-cap-without-star-logo
Seems to me that the outer chrome cap and cylinder are original, the rest may be taken from aftermarket cap. Or someone made nice logo and just replaced cylinder.
I will call Steven later ;) ;)
based on the keys in my post, is this cap OEM?
also...I have also seen caps with the MERCEDES emblem with one ring around and this one has 2
What's does my key code tell me?
do I ask the seller what the key code is?
I think your key code may start with N, KN or TN.
Key code is important if you want to have the keys matching those your car left factory with. Then you use the codes to cut the new keys to be the same.
You can ask the seller for the key code if you care about the key matching your data card. If the key profile matches the one from data card, you may try to make the cylinder fit the key code. But I have not tried it with fuel cap, I remember reading it is difficult to dismatle the cap to extract the lock cylinder.
If you have a single key that fits all locks, than i don't believe you'll be able to get the cap lock reconfigured to accept a double sided key, as the actual barrel is different on the later caps, it's in the centre of the barrel, have a look on here
https://www.authenticclassics.com/Late-280SL-Chrome-Gas-Cap-Plastic-Key-Head-p/auth-002470.htm
There are OEM gas caps with no markings on the bottom. See for example:
https://www.authenticclassics.com/190SL-Chrome-Locking-Gas-Cap-Vented-1955-61-p/auth-002475.htm
our capa should be unvented--correct?
TN
You would have to replace the barrel with the one with proper key profile.
Yes, but the construction of the parts is like on original caps - different than on the one discussed.
Correct.
spoke to the seller--this cap is vented
Pawel, are you referring to that round feature at the bottom of the cap? That also seems to exist on some OEM caps, for example, the one pictured below. (I'm assuming it's original, just from its weathered appearance)
My present theory about markings on the bottom is that it's marked 'Ohne Entluftung' if unvented, and unmarked if vented. And there is a key code if the cap originally came with the car, but not if the cap was sold as a replacement cap.
As far as rumours of installing a double-sided key barrel into a cap intended for a single-sided key barrel, it would be great to hear from someone who's actually done this. Generally, double-sided barrels (for doors etc) are larger diameter than single-sided ones. So for example, there's no way you can install a double-sided barrel in a door handle originally intended for single-sided key because of the differing diameters. The two-sided barrel is bigger to accommodate wafers on both sides of the key.
Does anyone know what feature of a gas cap is different between vented and unvented versions? It would seem to me that if it's simply a hole drilled somewhere, that you could plug that hole to convert from vented to unvented.
Many times, the vent is done through the lock. Would be difficult to plug. And then, why would you want to plug it?
Since our caps are supposed to be unvented, if you ended up buying a vented cap, you might want to plug the vent.
See how some of the theories can go to trash...
Is it Ymos too?
As for the cylinder (barrel) I am talking based on my experience with other locks in the car (I was re-creating sets of locks for 190SL form 1956 and Ponton from 1960). I never got into gas cap - I bought from the dealer about 10 years ago an original cap with lock cut to my key from data card for my Pagoda (it is in the drawer now, I use aftermarket one for every day), 190SL had vented cap with no lock and Ponton has door lock for fuel door. So I do not know if it is possible to change gas cap lock from asymetric key to symetric key. It is probably possible to cut the cylinder to the key if it has the correct profile.
The key that came with that gas cap, pictured below, is a Silca key with a TV profile (Silca YM5). I assume it's an aftermarket key. I also attach below a pdf of key equivalences, in case anyone's interested.
Looks original. If it is, it’s like gold. Hold on to it.
