W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Ahealey12 on July 27, 2024, 18:23:32
Title: Accelerator mounting help- any pics
Post by: Ahealey12 on July 27, 2024, 18:23:32
So transmission has had issues for years and my grandma said my step grandfather had had floor board replaced under the driver side at one point. Doing all the tests today linkage does not move and does ever hit 60psi as well. Test the continuity of the pedal switch and cone to find out they never mounted the accelerator pedal (pic).
Anyone have pics to show me where to mount it once i get the part? What part actually cones in contact to the switch under it?
Title: Re: Accelerator mounting help- any pics
Post by: dirkbalter on July 27, 2024, 19:11:48
I took these prior to replacing the floors. I might help.
Post by: Ahealey12 on July 27, 2024, 19:22:36
You the man! I already got it on order, truly appropriate this! Only thing i had found in German and wife couldn’t translate enough for me lol.
Post by: Kevkeller on July 28, 2024, 09:14:11
Is anyone able to take a picture of the pedal attached to that piece?  Mine has a hinge which doesn’t look anything like that piece.
Kevin
Post by: BobH on July 28, 2024, 15:26:56
Have a look on here Kevin, there seems to be different part numbers for the pedals, manual and auto, and different ages of cars, but i think they all connect the same way, onto the two balls
https://www.sl113.org/forums/index.php?topic=37520.msg274295#msg274295
Post by: Kevkeller on July 31, 2024, 15:03:53
Thank you Bob,
Kevin
