W113 Pagoda SL Group => Electrical and Instruments => Topic started by: CJHenderson on July 22, 2024, 22:50:28
Title: Kickdown switch for 280SL
Post by: CJHenderson on July 22, 2024, 22:50:28
It seems that there is no connector for my kickdown switch. I have looked everywhere inside my engine compartment with no luck. The wire color is red/black and brown/black.
https://www.sl113.org/wiki/Restricted/ColorWiringDiagrams
Title: Re: Kickdown switch for 280SL
Post by: lpeterssen on July 23, 2024, 19:38:03
Dear Mr. henderson
The kickdown connector is normally in a loom in the cabin in the same one that has the hig/low beam switch , and then continues behind the carpet to the right.  It exits the cabin through a hole above the accelerator pedal.
Best regards
L.Peterssen
Www.wiredoktor.com
Ps later I Will post a picture of that loom
Post by: CJHenderson on July 24, 2024, 00:08:09
Thank you for getting back to me.
Post by: dirkbalter on July 24, 2024, 00:20:05
Underneath the black tape, exiting the cabin as described above.
Post by: CJHenderson on July 24, 2024, 10:17:15
Thank you, found the holes. I should have taken photos of that area when stripping the interior out.
