W113 Pagoda SL Group => General Discussion => Topic started by: LindesayOne on May 30, 2024, 22:39:36
Title: Thermostat Housing Cap Gasket
Post by: LindesayOne on May 30, 2024, 22:39:36
As I reassemble my thermostat housing I'm baffled by how a seal is meant to be achieved between the cap and the base of the housing.
Is there a gasket and/or o-ring that is/are meant to go here? If so, who sells it/them? Nothing appears when the usual vendors' catalogues are searched.
Any suggestions would be much appreciated.
Title: Re: Thermostat Housing Cap Gasket
Post by: dirkbalter on May 30, 2024, 22:44:19
Item # 43, O-ring.
https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/50-cooling-system/50-c-cooling-system-280sl
Post by: LindesayOne on May 30, 2024, 23:57:30
Thanks Dirk......now that I inspect the the actual thermostat, it quickly becomes obvious that the o-ring is normally sold together with the thermostat, hence no separate listings.
Great parts illustration from SLS; must remember that!
