W113 Pagoda SL Group => Wanted To Buy => Topic started by: merrill on May 26, 2024, 12:21:40
hello,
looking for where i can find M5 thread chasers.
M5 x 0.8
M5 x 0.7
i did a google search but really did not have any luck.
i may need to search Ebay in the EU.
thanks in advance Matt
Going out on a limb here - I have never seen a M5x0.7. standard is M4x0.7 and M5x0.8
I have a set I purchased from my local hardware store. It has M4x0.7, M4x0.75, M5x0.8 and M5x0.9 amongst others. Have not seen an M4x0.8
MikeSimon
hi,
im am guessing this is an M5x0.7
M5X28-A2-70
maybe its not,
MikeSimon
hi,
M5X28-A2-70
maybe its not,
No idea!
Original text:
A2 - Stal nierdzewna AISI 304 - najpopularniejszy gatunek stali austenicznych o zawartości około 18% chromu i około 8% niklu. Dobra odporność na korozję. Typowa wytrzymałość to 700 MPa, czyli A2-70.
Google translated:
A2 - AISI 304 stainless steel - the most popular grade of austenitic steel with a content of approximately 18% chromium and approximately 8% nickel. Good corrosion resistance. Typical strength is 700 MPa, i.e. A2-70.
If you really, honestly and truly, have a non-standard thread size or one so obscure that you cannot find an off the shelf die or tap, you can always go custom: https://www.tapcotaps.com. I'm sure there are plenty more around the country or world.
Back in the mid 1970s when working on an Austin America (Austin 1200 to those across the world) we ran into such a threaded hole; I cannot be sure but it may have been on a flywheel or something. My father, then working in a research lab like Bell Labs, brought the part into the machine shop at work. Run by a German and so neat and clean, you could eat off the floor. Guenther measured the undamaged threads, decided they don't have a tap for that size...and made one for my father. We used it to chase the threads with a little bit of cutting oil. During the same era, he also made a clutch alignment tool for my Datsun 510. The local Datsun dealer was nice enough to let me look at it but wouldn't let it out of the shop. Armed with a caliper and graph paper, I drew the tool and Guenther made it for us. Sometimes that's what you have to do.
