W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Pawel66 on November 23, 2023, 16:33:49
Title: Oil Pump Clearances M130 Engine
Post by: Pawel66 on November 23, 2023, 16:33:49
Are the clearances for oil pump for M130 the same as for M127?
We have them in the older edition of BBB for M127. I found a post about them as well.
But I cannot find confirmation if they apply to M130, late, US.
Can you help confirming or directing to correct specs?
Thank you!
Title: Re: Oil Pump Clearances M130 Engine
Post by: Cees Klumper on November 24, 2023, 14:38:06
We'll need someone with access to the Tabellenbuch to look this up. Mine are on the old continent and I am in the Wild West unfortunately! But this is indeed an important issue. If I had to guess, I would say the clearances would be the same or very close, but that is only a guess.
Post by: Pawel66 on November 24, 2023, 17:06:09
Thank you for your kind attention Cees. Maybe someone chimes in. I looked at the new BBB today again - just description of changes. Haynes talks about clearances, but they do not give them…
