W113 Pagoda SL Group => Electrical and Instruments => Topic started by: dldubois on October 30, 2023, 16:41:33
Title: Becker buzz.....
Post by: dldubois on October 30, 2023, 16:41:33
I've got the original Becker cassette and amp in my car and I've got a background buzz that I just can't seem to shake.   Any thoughts on testing the noise suppression that I should have OR where to input to better address with aftermarket?   Super annoying.
Title: Re: Becker buzz.....
Post by: mmizesko on October 30, 2023, 19:26:49
I've got the same issue, even when the engine isn't running.  sent it back to Becker, worked for a while and then came back. I have the 71 stereo unit with the separate amp.
Mike Mizesko
Post by: BobH on October 30, 2023, 19:42:42
Hello, if it buzzes when the engine isn't running, perhaps check the earth/ground connections at the radio, amp and aerial, and the connections between them.  Could also be a damaged or bad speaker
Depends where the buzz is coming from
If it only buzzes when the engine is running, then check the above, but could then also be a bad suppression component, could be a long job checking or replacing all of those, there are details in the tech manual under radios/suppression
Post by: CJHenderson on October 30, 2023, 22:28:58
Try taking a grounding wire and attach one end to the radio Chassie and the other end to an existing ground source.
