W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: RAY on October 20, 2023, 08:40:54
Title: Automatic 1st gear selection
Post by: RAY on October 20, 2023, 08:40:54
Would it be possible (has any body done it ) on a 69' automatic to make the car pull away in first gear all the time without having to manually select 1st ?
Mine does it randomly sometimes and having done a diff change from 4.08 to 3.46, which works great for cruising, but would quite like the extra grunt pulling away especially on gradients.
Title: Re: Automatic 1st gear selection
Post by: BobH on October 20, 2023, 10:56:41
Hello Ray, i know very little about transmission, but i found this post
https://www.sl113.org/forums/index.php?topic=4914.msg30619#msg30619
It's not exactly automatic, need to press a button wired in circuit with the kickdown switch, but saves using the kickdown, or selecting 2 and then manually changing the gear
Post by: RAY on October 20, 2023, 11:57:40
Hi Bob,
Many thanks, I will message Tom with a few more questions.
Did you see the 1965 SL number plate auction ?
