W113 Pagoda SL Group => General Discussion => Topic started by: n/a on July 06, 2005, 13:01:47
Title: WIPER MOTOR SUBSTITUTE
Post by: n/a on July 06, 2005, 13:01:47
Having had the bad luck of buying 2 sl113's lately with duff wiper motor's, i set about looking for a suitable replacement. As the original is sat end on there is nothing made these days that is remotley similar.
The only way is to find a modern compact sideways fitting unit.After looking at hundreds finally found a BOSCH unit off a EUROPEAN MITSIBUSHI Charisma that as well as being compact allso had a longer drive shaft.
 I made a plate that was just a bit bigger than the original mount , drilled it for the replacement motor, sealed behind it etc, i had to drill a hole in behind half inch left of the original hole to get it in,
the wiper mechanism bolted straight up , no modifications. Getting the wiring right was more difficult , but i kept all the original wiring standard, now works great.
ADMINISTRATOR: I have removed the reference to your link to your commercial parts page. Placing commercial links is not allowed under our policy.
Title: Re: WIPER MOTOR SUBSTITUTE
Post by: Ben on July 07, 2005, 04:12:04
That looks pretty good ....welll done !
So would it be possible to utilse the variable intermittant feature at all !  Its one thing I find very irritating on these cars !
Post by: n/a on July 08, 2005, 00:46:31
keeping the wiring standard you will only get the 2 speed's.You would need to put in a seperate swich or relay to get intermittant wipe action . thanks LEVACE
Post by: Ben on July 08, 2005, 03:16:19
Yes its something I am considering doing, maybe with a descreet switch and rheostat somewhere ! Just wondered if you considered it at all !
