W113 Pagoda SL Group => Wanted To Buy => Topic started by: Brennie on August 03, 2023, 12:50:49
Hello
I’m trying to find an emergency/hazard light switch ,preferably with wiring loom but,just the switch would do.. thank you
What model 113 do you have?
-David
Bennie,
Take a look at your Profile options and find where you can create a signature, like David and I have done. Helps people a lot when answering your questions.
If anyone has one for an early pagoda, I’d be interested, look like this?
I bought a used one off a w114 . The wiring is fairly simple, the biggest problem was threading the switch/relay into position where they were fitted on later cars next to the light switch.
See UK eBay item 115854911589, you'll also need a plug to fit the 6 pins, (sls) wire and solder. I've got wiring details.
You might want one of these as well
https://www.authenticclassics.com/EMERGENCY-Sign-Hazard-Switch-Mercedes-230SL-250SL-p/auth-009149.htm
Thank you
Unfortunately this is the later variant of the switch 😔
I believe I have an old style one
email me at m300cab@gmail.com
