W113 Pagoda SL Group => Wanted To Buy => Topic started by: The_Molka on June 26, 2023, 19:32:06
hello,
as in subject, i'm looking for new socket pins for w113/w111 in fair price :)
regards T_M
Not sure about fair price but take a look.
https://www.sls-hh-shop.de/main/en/mercedes-190sl-w121-/54-b-wire-set/contact-bushing-4mm-brass-silver-plated-p-5663
What is this thing?
If you click on the red items in the box on the SLS link all will become clear!
I think they are the tiny female electrical plug 'sockets' that are used in the wiring harness, that wires are soldered into.
Some detail if needed...!
Oh, they go inside connectors. Cool.
Mercedes used to call them "bushings"
No. Mercedes did not call them "bushings". Bushing is not a German word. They may have called them "Hülse", maybe.
There are many standards for these pins that go inside plug fittings. You just have to figure out which one!
In a former life with computers, I used to use a lot of these that were made by Amphenol. They were crimp fittings, and there were small, inexpensive tools to both crimp them, and to place them inside the plastic connectors, and remove them from the connectors when needed. I would imagine the same exist for whatever standard these connectors are.
hello,
regards T_M
If I understand correctly what you are looking for is all here: https://www.sl113.org/wiki/Electrical/Connectors
The simplest way of getting them is at Mercedes. You will also get the right size by following the part numbers.
Fair price - they do not cost a fortune (ca $1-2), so unless you are after a couple of thousands, perhaps it is acceptable. You do not risk getting the wrong part. And you do not pay shipping, which would probably exceed value of connectors if you want 5-10 of them.
They are called contact pin or contact sockets.
Just modified this post by adding the below:
A good way of looking for "fair price" is to cross-reference the manufacturer part number with other manufacturers part numbers in a good internet store. If you take the pin bushing A 001 545 38 26 and cross reference it, you will get, for example, this:
https://www.iparts.pl/czesc/wtyk-herthbuss-50253950-herthbuss-elparts-50253950,0-72-50253950-3928266.html
Then if you check further in the tag "OEM Numbers" you will get part numbers for other producers.
They are not, however, available. This internet store, iparts, is a part of a large network and usually have better availabilities than other retailers.
The price is a little over $1. Then you add shipment - that is why I buy some of these things from Mercedes.
YES
Hi Molka,
How many do you need?
Male or female?
Chris
Cape Town
