W113 Pagoda SL Group => Wanted To Buy => Topic started by: Brennie on May 01, 2023, 15:12:11
Title: Boot/trunk panels..
Post by: Brennie on May 01, 2023, 15:12:11
Hi
I’m looking for a pair of those small square panels the cover the wires and number plate screws in the boot/trunk..as what’s not  in the picture ..
Not sure what to call them…
Thank you
Title: Re: Boot/trunk panels..
Post by: Peter on May 01, 2023, 19:48:57
Please look to SLS in Germany.
https://www.sls-hh-shop.de/main/en/mercedes-280-500sl-c-r-c107-/60-body-raw-frame-floors-and-panelling/63-64-c-boot-boot-floors-tail-panels-sl/cover-rear-panel-inner-p-6116
Post by: mda on May 02, 2023, 11:03:20
https://www.ebay.com/itm/224815185712?hash=item3458077f30:g:uMIAAOSwtixh9qLK&amdata=enc%3AAQAIAAAA4B8yqpnWMs0klPV4UrcvNb5v2%2B%2Bx8yh3kbBi82MF6k8hkRBY4ouUpacSnqH0ZwtKlA%2Fsa7gTUNiusWnzu9xUFjziPsyvIXb5WD%2BD5NMIq4dIg5u5owPDNJPJB734CZszDxQitpFEwiaKTbrpkmiWDGoPRzFRtJkeDXamLh0AkGlTak8vwu7CcUpEFQxaEvN4ntJKeNU506YoSZBmnlIt61O7hpBVrOiXLuoIiCu7FMjA2%2BxVA0SweKS1R1wurn7ySMowhK86GJnCgCWJe%2F0zVWchbQYIurUCuOpsVPbEqnWT%7Ctkp%3ABk9SR_6z_sH7YQ
Post by: mda on May 02, 2023, 11:05:35
https://www.ebay.com/itm/165997777100?_trkparms=amclksrc%3DITM%26aid%3D1110006%26algo%3DHOMESPLICE.SIM%26ao%3D1%26asc%3D247311%26meid%3D5d1f342fbb0d4e10b21af42f3eb63c83%26pid%3D101195%26rk%3D2%26rkt%3D12%26sd%3D224815185712%26itm%3D165997777100%26pmt%3D1%26noa%3D0%26pg%3D2047675%26algv%3DSimplAMLv11WebTrimmedV3MskuWithLambda85KnnRecallV1V4V6ItemNrtInQueryAndCassiniVisualRankerAndBertRecallCPCBlended%26brand%3DMercedes-Benz&_trksid=p2047675.c101195.m1851&amdata=cksum%3A1659977771005d1f342fbb0d4e10b21af42f3eb63c83%7Cenc%3AAQAIAAABUClE7Rni7LPdZba0E4PpnN9sqdNIfzrngjJmhUj%252BPVGabI8X4okIddREUp4Q0zc2AzeQ%252BYWQSxoBqGa9J%252Bx35NrBHVFYUVGsflNyHmFJfvouFhcLtSal3PrT8uqN34xP8tTkRtMZH%252Bjfqn4MA7rMqmpqqDsSAliP9AHR18Gcx8YOFhsU%252FAFA2UKm5NQGO%252FHuZuwT7TRJrb%252Bk39DrVX4sVuXu5PN20yL9wN%252BcWG%252FEDAqzkPcw3FrPRzE9%252F6bF44Pm%252Bs%252FlJd2TNBClcZE%252BjV%252FCQ%252BqK2UBJVSs59XiDO8cQctaRs6jkerlY0cmbcVxRjABDzb4ehDA2m17TuM8n%252FIGa6c3YJmXRZS3CV1umFk12bNn5pE6RBn8H5KFtZAYs8yqRDcpDeD%252Blz5K4Ylnyts20BwUPbRs%252FvX0gpob%252FaMcdau3GVP9%252Fn41ZZRNFYutxw3XUEw%253D%253D%7Campid%3APL_CLK%7Cclp%3A2047675
Post by: Brennie on May 02, 2023, 11:30:20
Thank you mda, so much for that tip… just what I’m looking for..
Perfect
Post by: Brennie on May 07, 2023, 13:05:18
So.. I now have those plates to cover the open panel in the trunk/boot.. but… what are the pieces protruding on the back of them?
Are they surplus to requirements on a W113?
The plate itself fits fine…
Post by: Jonny B on May 07, 2023, 15:04:47
Interesting. I had never seen anything like those before. They extra portion on the back has no application for the 113.
Post by: Brennie on May 07, 2023, 15:13:13
As I thought… multi using parts I’m guessing.. they actually fit if I bend the protrusions up all the way… serendipity…
Any idea what size screw fits there ? M4/6?
Post by: Pawel66 on May 07, 2023, 18:14:54
Metal sheet screws go there, if I remember correctly.
These brackets - could that be to hold wheel lug wrench and wheel alignment tool in early cars?
Post by: Brennie on May 07, 2023, 19:04:17
By trying to fit them..it seems the protrusions go on the inside?? In the body of the car…I may be wrong..
Post by: Pawel66 on May 07, 2023, 19:39:19
I think you see outside of the plate with bracket. I may be wrong of course.
Maybe check pout here: https://www.sl113.org/forums/index.php?topic=33042.msg241034#msg241034
Post by: BobH on May 07, 2023, 20:42:33
It looks like these covers were for the W114, slightly different than the ones on the W113
https://www.niemoeller.de/en/w114/w114/B010/45/f69032-cover-rear-center-piece-bottom-inside
