W113 Pagoda SL Group => General Discussion => Topic started by: Yi Li on March 12, 2023, 16:21:22
Hello, I have a 1968 280SL. It runs well. But I recently found I have to pull very hard to remove the engine oil dipstick and the upper portion of the dipstick is rusty. I can feel middle section of the tube is very tight. is this due to rust or collection of oil sludge? Is there a way to remove the tube and clean it? I did not see a bracket on the tube to fix it to engine body. Should I just pull tube upper or turn it to remove? Thanks in advance!
see here: https://www.sl113.org/forums/index.php?topic=34491.msg252320#msg252320.
...WRe
Thanks for the quick response. Can I clean the tube without remove it? I may use a stick wire brush to get rust or sludge off, but debris will fall into the oil tank. I can change oil immediately, will this hurt engine? Are there any other advices on how to clean the tube?
Thanks again!
