W113 Pagoda SL Group => Drive train, fuel, suspension, steering & brakes => Topic started by: Mohan58 on March 04, 2023, 02:49:23
Title: Rear Axle repair kit
Post by: Mohan58 on March 04, 2023, 02:49:23
Hi all,
I purchased the rear axle repair kit which consists of the left & right repair kit. See picture attached. Is there a step by step guide to do this? Please advise.
Cheers,
Mohan
Title: Re: Rear Axle repair kit
Post by: ja17 on March 04, 2023, 04:40:05
First of all make sure the wheel bearing on the right side is different than the bearing on the left side. The right side should use a special "self centering" barrel shaped roller bearing that allows the swing axle to change angle slightly. Next, most owners replace a lot of old rubber mounts, bushings, axle boot etc. before starting the work.
Post by: Mohan58 on March 05, 2023, 06:22:56
Thanks so much Joe. I did change all the bushes before but did not do this. Will take note in the right side.
Cheers
Mohan
Post by: badali on March 05, 2023, 13:37:21
I just did the left one on my 230SL.  Here is the link to mine with a few pictures...
https://www.sl113.org/forums/index.php?topic=34954.0
